DGS-1008D/H2EOL EOS
8-Port Gigabit Switch
Where to buy
Description
Effortless Gigabit Networking
With data transfer speeds of up to 2000Mbps on Gigabit Ethernet, the D-Link DGS-1008D 8-Port Gigabit Switch is ideal for transfering files quickly and online gaming. The DGS-1008D features front, easy-to-access Ethernet ports with two color LED indicators per port to easily distinguish link status. The switch features QoS, which organizes and prioritizes time-sensitive and important data for efficient delivery, allowing for smooth streaming media, VoIP calling, and online gaming. Additionally the switch features a Kensington Security Slot on the rear panel where users can fasten the unit to a table or desk.
Think Green
The DGS-1008D is a plug-and-play networking switch that features D-Link’s Green Technology to save energy and reduce heat, which in turn extends product life without sacrificing performance or functionality. The switch supports IEEE 802.3az Energy-Efficient Ethernet (EEE) which can detect when a connected computer is shut down or when there is no Ethernet traffic, and will proceed to power down the idle port, saving a substantial amount of power. In addition, the switch can also save energy by detecting the length of cable connected to a port and use only as much power as is required. Both of these features work together to help you save power automatically.
Environmentally Friendly
The switch was designed with the environment in mind. It is compliant with Energy Star Level V, CEC, and MEPS regulations which require the use of energy efficient power adapters. The switch is built to comply with RoHS standards to minimize use of hazardous materials and is packaged with an Energy Star Level V qualified power adapter in a recyclable packaging making this product truly environmental friendly.
General features
Key features
• Built-in D-Link Green Technology
• Inexpensive Gigabit solution for Home/SOHO
• Five 10/100/1000Mbps Gigabit ports
• 16Gbps switching fabric
• Auto MDI/MDIX crossover for all ports
• Secure store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Supports 9,000 Byte Jumbo Frames
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Supports Cable Diagnostics Function
• RoHS compliant
• Plug-and-play installation
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.1p QoS
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Gigabit Ethernet:
• 2000Mbps (full duplex)
Topology
• Star
Network cables
10BASE-T:
• UTP CAT 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX, 1000BASE-T:
• UTP CAT 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
LED indicators
• Per port: Link/Activity/Speed
• Per device: Power
Transmission method
• Store-and-forward
MAC address table
• 8K
MAC address learning
• Automatic update
Packet filtering/forwarding rates
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
• Gigabit Ethernet: 1,488,000pps per port
RAM buffer
• 128KB per device
DC Input
• External 5V/1A Level V power adapter
Power consumption
Power on (Standby):
• DC input: 0.55 watts
• AC input: 1.0 watts
Maximum:
• DC input: 2.8 watts
• AC input: 4.5 watts
Heat dissipation
Power on (Standby):
• AC input: 3.41BTU/h
Maximum:
• DC input: 9.548BTU/h
MTBF
• 2,053,751 hours
Operating temperature
• 0 to 50°C
Storage temperature
• -10 to 70°C
Operating humidity
• 10% to 90% RH non-condensing
Storage humidity
• 5% to 90% RH non-condensing
Device dimensions (W x D x H)
• 162 x 102 x 28mm
Certifications
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-Tick Class B
• VCCI Class B
• cUL
• CB
Certificates
Order info
DGS-1008D/H2 8-Port Gigabit Switch
Pictures
DGS-1008D/H2
Front view
Back view
Downloads
Support Resources
