DES-1005D/LEOL EOS
5-Port 10/100 Switch
Where to buy
Description
Auto-sensing 10/100 Ports
The DES-1005D uses auto-sensing 10/100Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-T and 100BASE-TX, as well as between full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX Crossover
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full. This gives you a more reliable connection for all of your connected devices.
General features
Key features
• Inexpensive Fast Ethernet solution for Home/SOHO
• Five 10/100Mbps Fast Ethernet ports
• Auto MDI/MDIX crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Plug-and-play installation
• RoHS compliant
Switching fabric
• 1Gbps
Standards
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x flow control
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Topology
• Star
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
Network cables
10BASE-T:
• UTP CAT 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX:
• UTP CAT 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
LED indicators
• Per port: Link/Activity
• Per device: Power
Transmission method
• Store-and-forward
MAC address table
• 2K entries per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
RAM buffer
• 64KBytes per device
DC Input
• External 5V/1A power adapter
Power consumption
Power on (Standby):
• DC input: 0.6 watts
• AC input: 1.5 watts
Maximum:
• DC input: 1.9 watts
• AC input: 4.3 watts
Heat dissipation
Power on (Standby):
• AC input: 5.115BTU/h
Maximum:
• AC input: 14.663BTU/h
Operating temperature
• 0 to 50°C
Storage temperature
• -10 to 70°C
Operating humidity
• 10% to 90% RH non-condensing
Storage humidity
• 5% to 90% RH non-condensing
Device dimensions (W x D x H)
• 125.3 x 83.4 x 29.1mm
Certifications
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-Tick Class B
• VCCI Class B
• cUL
• CB
Certificates
Order info
DES-1005D/L2 5-Port 10/100 Switch
Pictures
DES-1005D/L/L
Back view
Front view
Downloads
Support Resources
