DEM-302S-LXEOL EOS
SFP module with 1 port 1000BASE-LX, for single-mode fiber optic cable, power supply 3.3V (up to 2km)
Description
	D-Link’s 1G SFP Module series are hot-swappable Small Form Pluggable (SFP) transceivers that provide connectivity over fiber-optic cable. These fiber-optic transceivers have standard duplex LC connectors for connection compatibility. These transceivers can extend link distances up to 2km, which is a major improvement over the 100m limit of Ethernet cables. The SFP form is ideal for telecom enterprises which often require switches with SFP fiber modules to have flexible connections. The transceivers’ fiber link option is an excellent solution for use with fiber networks for large businesses or campuses.
	Small Form Pluggable Format
	The 1G SFP Module series transceivers use industry-standard Small Form Pluggable (SFP) form factor. The SFP modules slide into the mini GBIC slot of the Gigabit device, providing the necessary signal amplification for data to be transmitted to the network cable from the port, and for the port to receive data from the network cable.
	Hot Swappable
	All D-Link transceivers are hot-swappable. You can remove or replace the transceiver while the system is powered on without causing any problems. This permits modules to be added or swapped without interrupting the network.
	Gigabit Ethernet speeds
	The transceivers all support Gigabit Ethernet, which results in very fast data transmissions of up to 1Gbit/s. This enables the switches to handle fast and heavy data transmissions, making it suitable for business needs.
General features
	Standard
	IEEE-802.3z 1000BASE-LX
	Form Factor Type
	SFP
	Fiber Media Support
	Single-Mode
	Distance Capacity
	2km
	Features
	Hot Pluggable
	MSA Compliant
	RoHS Compliant
	Speed
	1Gbps
	Connector
	Duplex LC Connector
	Single/Bi-Directional
	Single Direction
	Wavelength
	1310nm
	Output Optical Power (TX Optical Power)
	Max.: -3dBm
	Min.: -10dBm
	Input Optical Power (RX Optical Power)
	Max.: -3dBm
	Min.: -21dBm
	Sensitivity
	-21dBm
	Cable Type
	Single-mode 9/125 um fber, reach: 2km
Certificates
Order info
DEM-302S-LX/10 SFP module with 1 port 1000BASE-LX, for single-mode fiber optic cable, power supply 3.3V (up to 2km)
