DEM-CB50
10G InfniBand Twinaxial Cable for connecting with CX4 devices, 50сm
Where to buy
Description
10G InfniBand Twinaxial Cables are designed to support high-speed connections for 10Gbps Ethernet devices*. The series consists of five models: the DEM-CB50, DEM-CB100, DEM-CB300, DEM-CB50ICX, and DEM-CB300CX. The 10G InfniBand Twinaxial Cables are an ideal solution for cost-effective, high-speed networking connectivity between D-Link switches, and other devices within a rack or in adjacent racks.
Ideal for High-Bandwidth Operation
The D-Link 10G InfniBand Twinaxial Cables support speeds of up to 10Gbps over distances of up to 3 metres. This 10GBASE-CX4 cabling runs over four pairs of twinaxial copper wiring, resulting in low latency, and supports the InfniBand fabric’s quality of service (QoS) and failover features. The result is an optimal solution for handling high bandwidth transmission over short distances.
10GBASE-CX4 Connectors
The 10G InfniBand Twinaxial Cables use 4X InfniBand connectors with screw or latch type plugs. The DEM-CB50, DEM-CB100, and DEM-CB300 feature screw-type connectors at both ends, and can be used as physical stacking cables or uplink cables for D-Link’s DGS-3120 L2 Managed Stackable Gigabit Switch series. The DEM-CB50ICX features a screw-type connector at one end for connection to the DGS-3120 series, and a latch-type connector at the other end for connection to the DMC-805X media converter. The DEM-CB300CX features a latch-type connector at both ends and can be used as a physical stacking cable for the DGS-3400 Series Advanced Layer 2+ Gigabit Switches and the accompanying DEM-410CX module.
* It is recommended that the 10G InfniBand Twinaxial Cables are only used with D-Link products.
General features
Connector Type
Screw-type at both ends
Cable Length
50cm
Wire AWG
28AWG
Connectivity
The cable for connecting the DGS-3120 series (recommended)
Voltage
30VAC
Current
0.5A
Operating temperature
-40 to 85°C
Certifications
• IEEE802.3ak 10GBASE-CX4
• SFF-8470
• EIA-364
• UL 94
Certificates
Order info
DEM-CB50  10G InfniBand Twinaxial Cable for connecting with CX4 devices, 50сm
Pictures
DEM-CB50
Front view
Downloads
Support Resources
