Quick find
Product features:
8-Port 10/100 Switch
EOL EOS
General features:
Key features
• Inexpensive Fast Ethernet solution for Home/SOHO
• Eight 10/100Mbps Fast Ethernet ports
• Auto MDI/MDIX crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Plug-and-play installation
• RoHS compliant
Switching fabric
• 1.6Gbps switching fabric
Standards
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x flow control
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Topology
• Star
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
Network cables
10BASE-T:
• UTP cat 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX, 1000BASE-T:
• UTP cat 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
LED indicators
• Per port: Link/Activity
• Per device: Power
Transmission method
• Store-and-forward
MAC address table
• 1K entries per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
RAM buffer
• 57Kbytes per device
DC Input
• External 5V/1.2A power adapter
Power consumption
Power on (Standby):
• DC input: 0.184 watts
• AC input: 0.986 watts
Maximum:
• DC input: 1.9 watts
• AC input: 2.74 watts
Heat dissipation
Power on (Standby):
• AC input: 3.365BTU/h
Maximum:
• AC input: 9.351BTU/h
Operating temperature
• 0 to 50°C
Storage temperature
• -10 to 70°C
Operating humidity
• 10% to 90% RH non-condensing
Storage humidity
• 5% to 90% RH non-condensing
Device dimensions (W x D x H)
• 164.5 x 111.5 x 36.0mm
Certifications
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-tick Class B
• VCCI Class B
• cUL
• CB
Products | Support  | News  | About |
