DES-1008D/К3EOL EOS
8-Port 10/100 Switch
Where to buy
Description
Auto-sensing 10/100 Ports
The DES-1008D uses auto-sensing 10/100Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-t and 100BASE-TX, as well as between full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX Crossover
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full. This gives you a more reliable connection for all of your connected devices.
Think Green
The D-link 8-port 10/100 Switch is part of D-link’s new series of SOHO devices that make use of D-link’s green technology, providing energy savings, reduced heat, and a longer product life without sacrificing performance or functionality. An energy-efficient power adapter (EnergyStar Level V qualified), minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly. The switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down.
General features
Key features
• Inexpensive Fast Ethernet solution for Home/SOHO
• Eight 10/100Mbps Fast Ethernet ports
• Auto MDI/MDIX crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Plug-and-play installation
• RoHS compliant
Switching fabric
• 1.6Gbps switching fabric
Standards
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x flow control
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Topology
• Star
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
Network cables
10BASE-T:
• UTP cat 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX, 1000BASE-T:
• UTP cat 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
LED indicators
• Per port: Link/Activity
• Per device: Power
Transmission method
• Store-and-forward
MAC address table
• 1K entries per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
RAM buffer
• 57Kbytes per device
DC Input
• External 5V/1.2A power adapter
Power consumption
Power on (Standby):
• DC input: 0.184 watts
• AC input: 0.986 watts
Maximum:
• DC input: 1.9 watts
• AC input: 2.74 watts
Heat dissipation
Power on (Standby):
• AC input: 3.365BTU/h
Maximum:
• AC input: 9.351BTU/h
Operating temperature
• 0 to 50°C
Storage temperature
• -10 to 70°C
Operating humidity
• 10% to 90% RH non-condensing
Storage humidity
• 5% to 90% RH non-condensing
Device dimensions (W x D x H)
• 164.5 x 111.5 x 36.0mm
Certifications
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-tick Class B
• VCCI Class B
• cUL
• CB
Certificates
Order info
DES-1008D/K3 8-Port 10/100 Switch
Pictures
DES-1008D/К3/K3
Back view
View from the right
Front view
Downloads
Support Resources
