DES-1016A
16-port 10/100 Switch
Description
	The DES-1016 16-port 10/100 Switch offers an economical way for small offices, homes, (SOHO) and small to medium businesses (SMB) to benefit from fast speed networking. It provides sixteen 10/100 ports for easy expansion of your network and a quick way to upgrade your network to Fast Ethernet connectivity.
	Fast Connectivity that Saves Energy
	The DES-1016 16-port 10/100 Switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down. The switch also conserves energy by adjusting power.
	Eco-friendly and Economical
	The D-Link DES-1016 16-port 10/100 Switch is part of D-Link’s new series of SOHO devices that make use of D-Link’s Green Technology, providing energy savings, reduced heat, and a longer product life without sacrificing performance or functionality. An energy-efficient power adapter (EnergyStar Level V qualified), minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
	Designed with the Environment in Mind
	The DES-1016 was designed with the environment in mind, and is compliant with Energy Star Level V, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
General features
	Key Features
	• D-Link Green Technology
	• 3.2Gbps switching fabric
	• Sixteen 10/100Mbps Fast Ethernet ports
	• Auto MDI/MDIX crossover for all ports
	Standards
	• IEEE 802.1P QoS support
	• ANSI/IEEE 802.3 NWay auto-negotiation
	• IEEE 802.3x Flow Control
	Functionality
	Data Transfer Rates
	• Ethernet:
	  • 10 Mbps (half duplex)
	  • 20 Mbps (full duplex)
	• Fast Ethernet:
	  • 100 Mbps (half duplex)
	  • 200 Mbps (full duplex)
	Network Cables
	• 10BASE-T:
	• UTP CAT 3, 4, 5/5e (100 m max.)
	• EIA/TIA-586 100-ohm STP (100 m max.)
	• 100BASE-TX, 1000BASE-T:
	• UTP CAT 5/5e (100 m max.)
	• EIA/TIA-568 100-ohm STP (100 m max.)
	LED Indicators
	• Per port: Link/Activity/Speed
	• Per device: Power
	Packet Filtering/Forwarding Rates
	• Ethernet: 14,880 pps per port
	• Fast Ethernet: 148,800 pps per port
	Media Interface Exchange
	• Auto MDI/MDIX adjustment for all ports
	Transmission Method
	• Store-and-forward
	RAM Buffer
	• 256 KBytes per device
	Protocol
	• CSMA/CD
Certificates
Order info
DES-1016A/E1 16-port 10/100 Switch
