DES-1016DEOL EOS
16 Port 10/100 Switch
Where to buy
Description
With the D-Link 16/24 Port 10/100 Switch, you can easily expand your business or home network by adding more computers and devices, each achieving speeds up to 200 Mbps per port in full-duplex mode. Quickly and securely connect employees working in small offices with one another and with all of the servers, printers, and other devices they use. High performance and reliable connectivity help speed file transfers and data processing, improve network
uptime, and keep your employees connected and productive.
Expand and Upgrade Your Network
The DES-1016D and DES-1024D offers an economical way for SOHO and small to medium businesses (SMB) to benefit from high-speed networking. It provides twenty-four ports for easy expansion of your network and a quick way to upgrade your network to Fast Ethernet connectivity. The switches speed file transfer times, improve slow and sluggish networks, keep your vital business applications available, and help your employees respond more quickly to customers and each other.
Conserve Energy
The DES-1016D 16 Port 10/100 Switch helps you conserve energy through IEEE802.3az EEE, which works when both the switch and its link partner are EEE-compliant devices. This powersaving feature automatically puts the switch into a low-power idle state when the switch utilization is zero, allowing you to lower your energy usage and save on your energy costs.
Designed with the Environment in Mind
The DES-1016D and DES-1024D are compliant with Energy Star Level V, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. They use recyclable packaging that helps reduce waste, complying with the WEEE directive. It’s innovatively designed to run cool and quiet without sacrificing performance.
General features
Standards
• IEEE 802.3 10BASE-T Ethernet (twisted pair copper)
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x flow control
• IEEE 802.3az EEE function
LAN
• IEEE 802.3u 100BASE-TX compliance
• IEEE 802.3x Flow Control support
Data Transfer Rates
• Fast Ethernet
• 100 Mbps Half-Duplex
• 200 Mbps Full-Duplex
• Ethernet
• 10 Mbps Half-Duplex
• 20 Mbps Full-Duplex
Fuctionality
Port Packet Filtering/ Forwarding Rate
• 148,800 pps for 100 M
• 14,880 pps for 10 M
Swithing Fabric
• 3.2 Gbps switching fabric
Number of Ports
• 16 10/100Mbps Fast Ethernet ports
Network Cables
• 10BASE-T:
• UTP CAT 3/4/5/5e (100 m max.)
• EIA/TIA-586 100-ohm STP (100 m max.)
• 100BASE-TX
• UTP CAT 5/5e (100 m max.)
• EIA/TIA-568 100-ohm STP (100 m max.)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all ports
LED Indicators
• Per port:
• Link/Activity
• Per device:
• Power
Transmission Method
• Store-and-forward
MAC Address Table
• 8K entries per device
MAC Address Learning
• Automatic update
Packet Filtering /Forwarding Rates
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 pps per port
Topology
• Star
Protocol
• CSMA/CD
Physical
Dimensions
• 280 x 125.8 x 44 mm (11.0 x 5.0 x 1.7 inches)
Weight
• 1.08kg(2.376lbs)
Power Consumption
• Power On (Standby):
• DC input: 0.23 Watts
• AC input: 0.8 Watts
• Max
• DC input: 1.32 Watts
• AC input: 2.1 Watts
Heat Dissipation
• AC input: 2.7296 BTU/h
• Maximum:
• AC input: 7.1652 BTU/h
MTBF
• 492,096 hours
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -10 to 70 °C (14 to 158 °F)
Certifications
• CE
• FCC
• ICES-003
• C-Tick
• cUL
• CB
Certificates
Order info
Pictures
DES-1016D
Back view
Front view
Downloads
Support Resources
