DGS-1100-24/MEEOL EOS
24-port 10/100/1000 Mbps
Description
	D-Link’s Gigabit Metro Ethernet Switches are ideal for Metro Ethernet applications, providing 16/24 copper connections on upgraded Gigabit Ethernet ports along with Gigabit SFP ports for improved uplink bandwidth if needed. They also offer resilience against electrical spikes with built-in surge protection, giving you a reliable solution you can count on.
	D-Link Green/Power Saving Performance
	Compliant with IEEE802.3az Energy Efficient Ethernet, these switches consume less energy by cutting down on power consumption when port utilization is low. By deploying EEE devices, users can cut operating costs and even cut down on necessary cooling equipment, helping small and medium-sized businesses stay within their budgets. The DGS-1100/ME Series also features D-Link Green Technology that helps automatically save energy. The switches monitor the link status of every port and will drastically reduce power consumption when a port link is down.
	Easy to deploy
	The DGS-1100/ME Series support an intuitive D-Link Network Assistant Utility and a command line management interface. The D-Link Network Assistant Utility allows customers to discover all D-Link switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC, and this also makes initial setup of the switches quick and easy. Switches within the same L2 network segment that are connected to the user’s PC are displayed on-screen for instant access. This allows for extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. The
	command line interface enables network administrators to remotely control their network down to the port level.
	QoS and Bandwidth Control
	The DGS-1100/ME Series supports Auto Surveillance VLAN (ASV), and Auto Voice VLAN, which are best suited for VoIP and video surveillance deployments. Auto Surveillance VLAN consolidates data and surveillance video transmission through a single DGS-1100/ME Series switch, thus sparing businesses the expense of dedicated hardware and facilities. ASV also ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data. The Auto Voice VLAN technology enhances the VoIP service by automatically placing voice traffic from an IP phone to an assigned VLAN. With higher priority and individual VLAN, these features guarantee the quality and security of VoIP traffic. Bandwidth Control can reserve bandwidth on a per port basis for important functions that require larger bandwidth or might have high priority.
	PoE Support
	The DGS-1100-24P/ME delivers Power over Ethernet (PoE) capabilities, making deployment with IP cameras, VoIP phones, and access points much easier. Power cords will become a thing of the past, as the DGS-1100-24P/ME complies with the 802.3af/802.3at standard for PoE and supports a 100 Watt power budget. The 10/100/1000Base-T Ethernet ports mean that even high quality video is no problem.
	Easy Troubleshooting
	The DGS-1100/ME Series feature Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. The Cable Diagnostics feature is designed for network administrators to quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
	Advanced Features
	The DGS-1100/ME Series is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to create a MAC whitelist for specific ports, helping administrators limit network access to authorized devices only. Storm Control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP Snooping is able to reduce the loading of L3 multicast routers and save bandwidth in network throughput.
General features
	Size
	• 11-inch Desktop/Rackmount Size, 1U Height
	Number of Ports
	• 24 10/100/1000 Mbps
	Port Functions
	• IEEE 802.3 compliant
	• IEEE 802.3u compliant
	• IEEE 802.3ab compliance
	• IEEE802.3af/802.3at (only for DGS-1100-24P/ME, ports 1 through 12)
	• Supports half/full-duplex operation (full/half at 10/100 Mbps, full at 1000 Mbps)
	• Auto-negotiation
	• Auto MDI/MDIX
	• IEEE 802.3x Flow Control supports Full-Duplex mode
	• IEEE 802.3az compliant
	Performance
	Switching Capacity
	• 48 Gbps
	Maximum Forwarding Rate
	• 35.71 Mpps
	MAC Address Table Size
	• 8K Entries
	Packet Buffer
	• 512 Kbits
	Flash Memory
	• 8 Mbyte
	LEDs
	• Power (per device)
	• Link/Activity/Speed (per port)
	Power Consumption
	• Maximum Power Consumption: 13.94 watts
	• Standby Mode: 10.37 watts
	Software Features
	VLAN
	• Port-based VLAN
	• 802.1Q Tagged VLAN
	• Auto Surveillance VLAN
	• Voice VLAN
	• Asymmetric VLAN
	• VLAN Group
	• Supports 128 static VLAN groups
	• Max. 4094 VIDs
	• Multicast VLAN
	L2 Features
	• Flow Control
	• 802.3x Flow Control
	• HOL Blocking Prevention
	• Jumbo Frames up to 9216 Bytes
	• IGMP Snooping
	• IGMP v1/v2/v3 awareness Snooping
	• Supports 64 Groups
	• IGMP Snooping Querier
	• MLD Snooping
	• MLD v1/v2 awareness snooping
	• Supports 64 groups
	• MLD snooping querier
	• 802.3ad Link Aggregation:
	  • Support max 12 groups per device and 8 ports per group
	• Loopback Detection
	• Cable Diagnostics
	• LLDP
	• Port Mirroring
	• One-to-One
	• Many-to-One
	• Statistics
	• Tx Ok
	• Tx Error
	• Rx Ok
	• Rx Error
	• Spanning Tree Protocol
	• 802.1D STP
	• 802.1w RSTP
	Quality of Service (QoS)
	• 802.1p Quality of Service
	• 4 queues per port
	• Queue Handling
	• Strict
	• Weighted Round Robin (WRR)
	• Port-based Bandwidth Control (Rate Limiting)
	• Ingress : 8Kbps, Egress : 64Kbps
	Security
	• D-Link Safeguard
	• Traffic Segmentation
	• DoS Attack Prevention
	• Broadcast/Multicast/Unknown Unicast Storm Control
	Management
	• Command line interface (via Telnet)
	• D-Link Network Assistant Utility
	Green Technology
	• Power Saving by
	• Link Status
	• LED Shut-Off
	• Port Shut-Off
	• System Hibernation
	• Compliant with IEEE 802.3az Energy Efficient Ethernet
	MIB/RFC Standards
	• RFC 768 UDP
	• RFC 791 IP
	• RFC 792 ICMP
	• RFC 793 TCP
	• RFC 826 ARP
	• RFC 1213 MIB II
	• RFC1493 Bridage MIB
	• RFC1907 SNMPv2 MIB
	• RFC2233 Interface Group MIB
	• RFC2665 Ether-like MIB
	• 802.1p MIB RFC4363
	• ZoneDefense MIB
	• Private MIB
	• RFC 951 BootP Client
	• RFC 1542 BootP/DHCP client
	• RFC 4363 802.1p
	• RFC 2236 IGMP Snooping
	Physical
	Power Input
	• Power Input 100 to 240 V AC
	• 50 to 60 Hz Internal Power Supply
	MTBF
	• 2,406,109 hours
	Acoustics
	• 0 dB(A)
	Heat Dissipation
	• 47.57 BTU/hr
	Weight
	• 1.63 kg (3.59 lbs)
	Dimensions
	• 280x 180x 44 mm (11.02 x 7.08 x 1.73 inches)
	Ventilation
	• Fanless
	Operating Temperature
	• -5 to 50 °C (23 to 122 °F)
	Storage Temperature
	• -40 to 70 °C (-40 to 158 °F)
	Operating Humidity
	• 0% to 95% non-condensing
	Storage Humidity
	EMI
	• FCC Class A, CE Class A, VCCI Class A, C-Tick, BSMI, CCC
	Safety
	• cUL, CE LVD, CB, BSMI, CCC
Certificates
Order info
DGS-1100-24/ME 24-port 10/100/1000 Mbps
	Optional SFP Transceivers
	DGS-712  1000 Base-T copper
	DEM-310GT  1000BASE-LX, single-mode, 10 km
	DEM-311GT  1000BASE-SX, multi-mode, 550 m
	DEM-312GT2  1000BASE-SX, multi-mode, 2 km
	DEM-314GT  1000BASE-LHX, single-mode, 50 km
	DEM-315GT  100BASE-ZX, single-mode, 80 km
	DEM-330T/R  Gigabit WDM transceiver, single-mode 10 km
	DEM-331T/R  Gigabit WDM transceiver, single-mode 40 km
