DGS-3000-26TC
20-Port 10/100/1000 BASE-T + 4-Port Combo 10/100/1000BASE-T/SFP + 2-Port 10G SFP+, L2 Management Switch
Where to buy
Description
Reliable Networking
All of the Ethernet ports of the DGS-3000 Series support 6kV surge/lightning protection. This feature protects the switch from power surges due to lightning or improper electrical wiring when the Ethernet cables are exposed in open spaces, such as in old buildings. The switch also provides an additional power connector for connection to D-Link’s DPS-200 Redundant Power Supply, or a stable, protected 12VDC backup power source in case of a main power failure. For Ethernet link fail-over, the DGS-3000 Series supports 802.1D Spanning Tree Protocol (STP), 802.1w Rapid Spanning Tree Protocol (RSTP), and 802.1s Multiple Spanning Tree Protocol (MSTP), to allow automatic backup of bridge paths. Using these features, the transmission and reception of frames can be guaranteed even during a network failure. For mission critical environments, the switches also support ITU-I G.8032 Ethernet Ring Protection Switching (ERPS); traffic can be rerouted around the ring within 50 milliseconds, minimizing disruption to service. D-Link Loopback Detection (LBD) is a protocol-less loop detection function that prevent loop events from causing congestion in uncontrolled network segments such as unmanaged switches or customer networks. The DGS-3000 Series also support 802.1AX and 802.3ad Link Aggregation, which allows grouping of multiple ports in parallel to increase bandwidth and redundancy for high availability and load sharing in a multi-client environment.
Deliver Triple Play Services
The DGS-3000 Series features full L2 multicast functions, including IGMP/MLD snooping, fast leave, and filtering. With L2 multicast support, the switches can handle the increasingly popular IPTV service. Host-based IGMP/MLD Snooping provide service to multiple IPTV subscribers per physical interface and ISM VLAN registers multicast streams in a multicast VLAN to save bandwidth on the network backbone. The ISM VLAN profiles allow users to bind or replace the channel profiles of subscription ports quickly and easily. The DGS-3000 Series also supports IGMP authentication, which can prevent rogue IPTV subscriptions by authenticating Set Top Boxes as well as channel switching to secure Internet Service Provider (ISP) revenues.
The DGS-3000 Series also supports advanced Quality of Service (QoS) functions to help ISPs reliably deliver high-quality triple play services. Flexible packet classification can be based on various header fields or user-defined packet content to help administrators prioritize network traffic. Two-rate and single-rate Three Color Marker (trTCM/srTCM) help classify traffic streams into conforming and nonconforming groups to guarantee the minimum bandwidth for prioritized packets. The Bandwidth Control feature allows ISPs to define the upstream/downstream throughput levels for each port with granularity down to 64 kbps.
Easy Maintenance and Troubleshooting
The DGS-3000 Series features rich Operations, Administration, and Management (OAM) features to help ISPs reduce the burden of maintenance and troubleshooting. Cable diagnostics display the status of Ethernet cables and locate the position of cable errors remotely, helping providers cut on-site support costs. 802.1ag Connectivity Fault Management (CFM) provides administrators with a convenient tool to monitor and troubleshoot end-to-end service networks. This allows service providers to check connectivity, isolate network issues, and identify the affected customers. D-Link Unidirectional Link Detection (DULD) helps detect a broken one-way fiber connection, improving the stability of the fiber infrastructure in a Metropolitan Area Network.
Solid Security with High Availability
The DGS-3000 Series offers various user/device authentication features including 802.1X, Web-based Access Control (WAC)2 and MAC-based Access Control (MAC). The clientless WAC2 and MAC functions provide convenience for IT managers implementing user/device authentication into a network. It permits administrators to control security without installing client software on each network device; this is especially important for devices on which the software cannot be installed. For a greater security level, the DGS-3000 Series also supports Compound Authentication2, letting IT managers choose between multiple authentication methods for any single device. Selectable host-based authentication and authorization provides the option to finely control access by each device in the network. For advanced applications, the switches also provide RADIUS and TACACS accounting information for integration of backend services such as a billing system or advanced user/device control. In mission critical networks, the DGS-3000 Series supports strict address and interface binding function via IP-MAC-Port Binding and ARP Spoofing Prevention to protect the networks from Man-In-The-Middle or ARP Spoofing attacks.
To maintain a high availability network, the DGS-3000 Series uses D-Link Safeguard Engine to manage the CPU and ensure that your network stays up even if it is overloaded by malicious traffic caused by worms and viruses. The switches also support DHCP Screening to filter out unauthorized DHCP offerings from rogue DHCP servers or routers. Other security features such as BPDU Attack Protection, DoS Attack Prevention, and L3 Control Packet Filtering help to block leaks caused by protocol or behavioral security intrusions.
IPv6 Ready
The DGS-3000 Series is IPv6 ready and supports various IPv6 functions such as MLD Snooping, WAC2, IPv6 ACL/QoS, and IMPBv6 to ensure seamless integration of next generation networks. The DGS-3000 Series also supports a IPv4/v6 dual stack function that allows the switch to act as a bridge between IPv4 and IPv6 networks. Finally, all DGS-3000 Series are certified to be IPv6 ready, which guarantees interoperability for IPv6 environments.
General features
Interface
Ports
• 20-Port 10/100/1000BASE-T
• 4-Port Combo 10/100/1000BASE-T/SFP
• 2-Port 10G SFP+
Optional Redundant Power Supply
• DPS-2003
Console Port
• RJ-45
Performance
• Switching Capacity: 88 Gbps
• 64 Byte Packet Forwarding Rate: 65.48 Mpps
• MAC Address Table: 16K Entries
• DRAM for CPU: 128 MB
• Packet Buffer Memory: 1.5 MB
• Flash Memory: 32 MB
• Jumbo Frame: 12,288 Bytes
Software Features
Virtual Stacking
• D-Link Single IP Management
• Up to 32 units per Virtual Stack
L2 Features
• 16K MAC Address Table
• Flow Control:
- 802.3x Flow Control
- HOL Blocking Prevention
• Jumbo Frames up to 12K bytes
• Spanning Tree Protocols:
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
• BPDU Filtering
• Root Restriction
• Loopback Detection
• Link Aggregation:
- Compliant with 802.1AX and 802.3ad
- Max. 13 groups, 8 ports per group
• Port Mirroring:
- Supports 1 Mirroring group
- Supports One-to-One, Many-to-One, Flow-based (ACL) Mirroring
• Ethernet Ring Protection Switching (ERPS)
L2 Multicasting
• IGMP Snooping:
- IGMP v1/v2 Snooping, v3 awareness
- Supports 1024 groups
- Port/Host-based IGMP Snooping Fast Leave
- Report Suppression
• IGMP Authentication
• IGMP/MLD Proxy Reporting
• Limited IP Multicast (IGMP Filtering)
• MLD Snooping:
- MLD v1, MLD v2 awareness
- Host-based MLD snooping Fast Leave
VLAN
• VLAN Group:
- Max. 4094 VLAN
• Port-based VLAN
• MAC-based VLAN
• GVRP:
- Max. 255 dynamic VLANs
• 802.1v Protocol VLAN
• 802.1Q Tagged VLAN
• Double VLAN (Q-in-Q):
- Port-based Q-in-Q
- Selective Q-in-Q
• ISM VLAN
• VLAN Translation
• Voice VLAN
• VLAN Trunking
• Asymmetric VLAN
L3 Features
• Support 1024 ARP Entries
• Gratuitous ARP
• Default Route
• 8 queues per port
• DSCP
• 802.1p
• Bandwidth Control:
- Port-based (Ingress/Egress, min. granularity 64 kbps)
- Flow-based (Ingress/Egress, min. granularity 64 kbps)
- Per egress queue bandwidth control (min. granularity 64 kbps)
• Queue Handling:
- Strict Priority Queue (SPQ)
- Weighted Round Robin (WRR)
- Deficit Round Robin (DRR)
- SPQ + WRR
• Supports the following actions for flows:
- Remark 802.1p Priority Tag
- Remark TOS/DSCP Tag
• Time-based QoS
• Three Color Marker
- trTCM
- srTCM
• CoS Based on:
- 802.1p Priority Queues
- VLAN ID
- MAC Address
- Ether Type
- IPv4/v6 Address
- IPv6 Traffic Class
- IPv6 Flow Label
- DSCP
- Protocol Type
- TCP/UDP Port
- User-Defined Packet Content
Access Control List (ACL)
• ACL based on:
- Switch Port
- 802.1p Priority
- VLAN ID
- MAC Address
- Ether Type
- IPv4/v6 Address
- IPv6 Flow Label
- DSCP
- Protocol Type
- TCP/UDP Port Number
- User Defined Packet Content
• Up to 1024 ingress access rules
• Time-based ACL
• ACL Statistics
• CPU Interface Filtering
Security
• SSH v1/v2
• SSL v1/v2/v3
• Port Security
- Up to 64 MAC addresses per port
• Broadcast/Multicast/Unicast Storm Control
• IP-MAC-Port Binding (IMPB):
- ARP Inspection
- IP Inspection
- DHCP Snooping
• Traffic Segmentation
• D-Link Safeguard Engine
• L3 Control Packet Filtering
• NetBIOS/NetBEUI Filtering
• DHCP Server Screening
• DHCP Client Filtering
• ARP Spoofing Prevention
• BPDU Attack Protection
• DoS Attack Prevention
AAA
• 802.1X
- Port-based Access Control
- Host-based Access Control
- Dynamic VLAN Assignment
• MAC-based Access Control (MAC)
• Web-based Access Control (WAC)2
• Japan Web-based Access Control (JWAC)
• Compound Authentication2
• Microsoft® NAP (IPv4/v6)
- Supports 802.1x NAP
- Supports DHCP NAP
• Guest VLAN
• RADIUS (IPv4/v6)
• TACACS
• TACACS+
• XTACACS+
• Trusted Host
• RADIUS Accounting
• TACACS+ Accounting
• Four-level User Account
OAM
• Cable Diagnostics
• 802.3ah Ethernet Link OAM
• 802.3ah D-link Unidirectional Link Detection (DULD)
• Y.1731 OAM 2
• sFlow
Green Features
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Power-saving function
• Link Status
• Cable Length
• LED Shut-Off
• Port Shut-Off
• Port Standby
• System Hibernation
Management
• Web-based GUI (Supports IPv4/v6)
• Command Line Interface (CLI)
• Telnet Server/Client (Supports IPv4/v6)
• TFTP Client (Supports IPv4/v62)
• FTP Client (Supports IPv4/v6)
• ZModem
• Command Logging
• SNMP v1/v2c/v3
• SNMP Traps
• System Log
• SMTP
• RMON v1:
- Supports 1,2,3,9 groups
• RMON v2:
- Supports Probe Config group
• 802.1AB LLDP
• LLDP-MED
• BootP/DHCP Client
• DHCP Auto-Configuration
• DHCP Relay (Support IPv4)
• DHCP Relay Option 60, 61 and 82
• DHCP Client Option 12
• PPPoE Circuit-ID Tag Insertion
• Multiple Image
• Flash File System
• CPU Monitoring
• Memory Monitoring
• NTP/SNTP
• Debug Command
• Password Recovery
• Password Encryption
• Ping (Supports IPv4/v6)
• Traceroute
• Microsoft® NLB (Network Load Balancing) Support
MIB
• RFC1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC1213 MIB II
• RFC1493, 4188 Bridge MIB
• RFC1157, 2571-2576 SNMP MIB
• RFC1901-1908, 3418, 3636, 1442, 2578 SNMPv2 MIB
• RFC271,1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665, 3635 Ether-like MIB
• RFC2668 802.3 MAU MIB
• RFC2674, 4363 802.1p MIB
• RFC2233, 2863 Interface Group MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC3298 MIB for Diffserv
• RFC 2925 Ping & Traceroute MIB
• Running configuration write and backup
• TFTP uploads and downloads
• Trap MIB
• RFC 2465 IPv6 MIB
• RFC 2466 ICMPv6 MIB
• RFC 2737 Entity MIB
• Private MIB
• RFC 3289 DIFFSERV MIB
IETF® Standards
• RFC768 UDP
• RFC791 IP
• RFC792 ICMPv4
• RFC2463, 4443 ICMPv6
• RFC4884 Extended ICMP to Support Multi-Part Messages
• RFC793 TCP
• RFC826 ARP
• RFC1338, 1519 CIDR
• RFC2474, 3168, 3260 Definition of the DS Field in the IPv4 and IPv6 Header
• RFC1321, 2284, 2865, 2716, 1759, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
IPv6
• RFC2460 IPv6
• RFC2461, 4861 Neighbor Discovery
• RFC2462, 4862 IPv6 Stateless Address Auto-configuration
• RFC2464 IPv6 Neighbor over Ethernet and definition
• RFC3513, 4291 IPv6 Addressing Architecture
• RFC2893, 4213 IPv4/IPv6 dual stack function
• IPv6 Ready Logo Phase 2
Physical
MTBF(hours)
• 472842.5 h
Acoustic
• 47.8 dB
Heat Dissipation
• 100.94 Btu/h
Power Input
• AC Input 100 to 240 V AC, 50 to 60 Hz Internal Universal Power Supply
Max Power Consumption
• 29.6 W
Dimensions (W x D x H)
• 441 x 209.9 x 44 mm
Weight
• 2.01 kg
Ventilation
• Smart Fan (Turns on at > 40 C; Turns off at < 35 C)
Power Surge Protection
• All Ethernet ports support IEC61000-4-5 10/700us 6 kV surge protection
Operation Temperature
• 0 to 50°C (32 to 122°F)
Storage Temperature
• -40 to 70°C (-40 to 158°F)
Operation Humidity
• 10% to 90% RH
Storage Humidity
• 5% to 90% RH
Emission (EMI)
• CE, FCC, IC, C-Tick, VCCI, BSMI
Safety
• CB, UL/cUL, BSMI
Certifications
2Available in the future
3Please use DPS-CB150-2PS for connecting DPS-200 to DGS-3000.
Certificates
Order info
DGS-3000-26TC 20-Port 10/100/1000 BASE-T + 4-Port Combo 10/100/1000BASE-T/SFP + 2-Port 10G SFP+, L2 Management Switch
Redundant Power Supply and Cable
DPS-200 60-watt RPS with a 1-meter DC power cable
DPS-CB150-2PS The RPS cable for DGS-3000 and DPS-200
Optional Management Software
DV-600S D-View 6.0 Network Management System (Standard Edition)
DV-600P D-View 6.0 Network Management System (Professional Edition)
Optional Accessories
DEM-CB100S 10-GbE SFP+ 1m Direct Attach Cable
DEM-CB300S 10-GbE SFP+ 3m Direct Attach Cable
DEM-CB500S 10-GbE SFP+ 5m Direct Attach Cable
DEM-CB700S 10-GbE SFP+ 7m Direct Attach Cable
DEM-CB100QXS-4XS 40G QSFP+ to 4-Port 10G SFP+ 1m Direct Attach Cable
Optional SFP Transceivers
DEM-302S-LX1000BASE-LX, Single-mode, 2 km
DEM-310GT1000BASE-LX, Single-mode, 10 km
DEM-311GT1000BASE-SX, Mutli-mode, 550 m
DEM-312GT21000BASE-SX, Multi-mode, 2 km
DEM-314GT1000BASE-LHX, Single-mode, 50 km
DEM-315GT1000BASE-ZX, Single-mode, 80 km
DGS-7121000BASE-T Copper SFP Transceiver
DEM-210100Mbps Single-Mode SFP Transceiver, 15 km
DEM-211100Mbps Multi-Mode SFP Transceiver, 2 km
Optional WDM SFP Transceivers
DEM-302S-BXDGigabit WDM(BiDi) Single-Mode 2KM SFP Transceiver (TX-1550/RX-1310 nm)
DEM-302S-BXUGigabit WDM(BiDi) Single-Mode 2KM SFP Transceiver ( TX-1310/RX-1550 nm)
DEM-330RGigabit WDM(BiDi) Single-Mode 10KM SFP Transceiver (TX-1310/ RX-1550 nm)
DEM-330TGigabit WDM(BiDi) Single-Mode 10KM SFP Transceiver (TX-1550/ RX-1310 nm)
Optional SFP+ Transceivers
DEM-431XT10GBASE-SR SFP+ Transceiver (w/o DDM), 80 m: OM1 & OM2 MMF,300 m: OM3 MMF
DEM-431XT-DD10GBASE-SR SFP+ Transceiver (with DDM), 80 m: OM1 & OM2 MMF, 300 m: OM3 MMF
DEM-432XT10GBASE-LR SFP+ Transceiver (w/o DDM), 10 km
DEM-432XT-DD10GBASE-LR SFP+ Transceiver (with DDM), 10 km
DEM-433XT10GBASE-ER SFP+ Transceiver (w/o DDM), 40 km
DEM-433XT-DD10GBASE-ER SFP+ Transceiver (with DDM), 40 km
DEM-435XT10GBASE-LRM SFP+ Transceiver (w/o DDM), 220 m: OM1 & OM2 MMF, 300 m: OM3 MMF
DEM-435XT-DD10GBASE-LRM SFP+ Transceiver (with DDM), 220 m: OM1 & OM2 MMF, 300 m: OM3 MMF
DEM-436XT-BXU10GBASE-LR BiDi SFP+ Transceiver (w/o DDM), 20 km; TX: 1270 nm, RX: 1330 nm
DEM-436XT-BXD10GBASE-LR BiDi SFP+ Transceiver (w/o DDM), 20 km; TX: 1330 nm, RX: 1270 nm
Pictures
DGS-3000-26TC/DC
Front view
Back view
View from the right
DGS-3000-26TC
Front view
View from the right
Back view
Downloads
Support Resources
