Quick find
Product features:
48 10/100/1000 Mbps ports + 4 10G SFP+ ports Metro Ethernet Switch
Project
General features:
Hardware Version
• A1
Interface
Size
• 19-inch standard rack-mount width
• 1U height
Interface
• 48 10/100/1000 Mbps + 4 10G SFP+
Console Port
• RJ-45 Console Port
Port Standards & Functions
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• IEEE 802.3ae 10 GbE
• IEEE 802.3x Flow Control for full-duplex mode, auto-negotiation
Network Cables
• UTP Cat. 5, Cat. 5e (100 m max.); EIA/TIA-568 100-ohm STP (100 m max.)
Full/Half-Duplex
• Full/half-duplex for 10/100 Mbps and Gigabit speed
Media Interface Exchange
• Auto or configurable MDI / MDIX
Performance
• Switching Capacity: 176 Gbps
• Forwarding Method: Store-and-forward
• MAC Address Table Size: Up to 16K entries per device
• MAC Address Update: Up to 512 static MAC entries
• Maximum 64-byte Max. Packet Forwarding Rate: 130.95 Mpps
• Packet Buffer: 3.0 MB per device
LEDs
• Power (per device)
• Redundant Power Supply (RPS) (per device)
• Console (per device)
• Link/Active/Speed (per port)
• Fan Error
Software Specifications
Virtual Stacking
• D-Link Single IP Management
- Up to 32 units per Virtual Stack
L2 Features
• MAC Address Table: Up to 16K
• Flow Control
- 802.3x Flow Control
- HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• Spanning Tree Protocols
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
• BPDU Filtering
• Root Restriction
• Loopback Detection
• Link Aggregation
- Compliant with 802.1AX and 802.3ad
• Port Mirroring
- Supports 1 Mirroring group
- Supports One-to-One, Many-to-One, Flow-based (ACL)
Mirroring
• Ethernet Ring Protection Switching (ERPS)
L2 Multicasting
• IGMP Snooping
- IGMP v1/v2 Snooping, v3 awareness
- Supports 1024 groups
- Port/Host-based IGMP Snooping Fast Leave
- Report Suppression
- IGMP Authentication
- Limited IP Multicast (IGMP Filtering)
• MLD Snooping
- MLD v1, MLD v2 awareness
- Port/Host-based MLD snooping Fast Leave
VLAN
• VLAN Group
- Max. 4094 VLAN
• Port-based VLAN
• MAC-based VLAN
• GVRP
- Max. 255 dynamic VLANs
• 802.1v Protocol VLAN
• 802.1Q Tagged VLAN
• Double VLAN (Q-in-Q)
- Port-based Q-in-Q
• ISM VLAN
• VLAN Translation
• VLAN Trunking
L3 Features
• Max. 1024 ARP entries
- Supports 255 static ARP entries
• Gratuitous ARP
• 16 IP interfaces
• Default Route
• Static Route1
- 64 IPv4 static routes1
- 32 IPv6 static routes1
Quality of Service (QoS)
• CoS based on
- Switch Port
- 802.1p Priority
- VLAN ID
- MAC Address
- Ether Type
- IPv4/IPv6 address
- DSCP
- ToS
- Protocol Type
- TCP/UDP Port
- IPv6 Traffic Class
- IPv6 Flow Label
- User Defined Packet Content
• Bandwidth Control
- Port-based (Ingress, Min. Granularity 64 Kbps)
- Flow-based (Ingress, Min. Granularity 64 Kbps)
- Egress queue bandwidth control (Min. Granularity 64 Kbps)
• Queue Handling
- Strict Priority Queue (SPQ)
- Weighted Round Robin (WRR)
- SPQ + WRR
• 8 queues per port
Access Control List (ACL)
• ACL based on
- Switch Port
- 802.1p Priority
- VLAN ID
- MAC Address
- Ether Type
- IPv4/IPv6 Address
- IPv6 Flow Label
- DSCP
- ToS
- Protocol Type
- TCP/UDP Port
- User-defined Packet Content
• Up to 1024 ingress access rules
• Time-based ACL
• ACL Statistics
• CPU Interface Filtering
AAA
• 802.1X
- Port-based Access Control
- Host-based Access Control
- Dynamic VLAN Assignment
• MAC-based Access Control (MAC)
• Microsoft® NAP (IPv4)
• Guest VLAN
• RADIUS (IPv4)
• TACACS (IPv4)
• TACACS+ (IPv4)
• XTACACS+ (IPv4)
• Trusted Host
• RADIUS Accounting
• Four-level User Account
Security
• SSH v1/v2
• SSL v1/v2/v3
• Port Security
- Up to 64 MAC addresses per port
• Broadcast/Multicast/Unicast Storm Control
• IP-MAC-Port Binding (IMPB)
- ARP Inspection
- IP Inspection
- DHCP Snooping
- DHCPv6 Snooping1
- DHCPv6 Guard1
- IPv6 Route Advertisement (RA) Guard1
- IPv6 ND Snooping1
- IPv6 ND Inspection1
• Traffic Segmentation
• D-Link Safeguard Engine
• L3 Control Packet Filtering
• NetBIOS/NetBEUI Filtering
• DHCP Server Screening
• DHCP Client Filtering
• ARP Spoofing Prevention
• BPDU Attack Protection
• DoS Attack Prevention
OAM
• Cable Diagnostics
• 802.3ah Ethernet Link OAM
• Dying Gasp
Management
• Web-based GUI (Supports IPv4/v6)
• Command Line Interface (CLI)
• Telnet Server/Client (Supports IPv4)
• TFTP/FTP Client (Supports IPv4)
• ZModem
• Command Logging
• SNMP v1/v2c/v3 (Supports IPv4)
• SNMP Traps
• System Log
• SMTP (IPv4)
• RMON v1:
- Supports 1,2,3,9 groups
• RMON v2:
- Supports Probe Config group
• 802.1AB LLDP
- LLDP-MED
• BootP/DHCP Client (Supports IPv4)
• DHCP Auto-Configuration1
• DHCP Relay (Supports IPv4)
- DHCP Relay Option 60, 61 and 82
- DHCP Client Option 12
• PPPoE Circuit-ID Tag Insertion1
• Multiple Image
• Flash File System
• CPU Monitoring
• Memory Monitoring
• SNTP (Supports IPv4)
• Debug Command
• Password Recovery
• Password Encryption
• Ping
• Traceroute
• Microsoft® NLB (Network Load Balancing) Support (Supports IPv4)
• Zero Touch Provisioning (ZTP)1
• sFlow1
• D-Link Network Assistant1
Physical/Environmental
MTBF
• 465,240 hours
Acoustic
• 45,9 dB(A)
Heat Dissipation
• 145.948 BTU/h
Power Input
• AC Input: 100 to 240 VAC 50/60 Hz
Maximum Power Consumption
• 40.7 W
Standby Power Consumption
• 28.6 W/100 V
• 28.9 W/240 V
Dimensions (W x D x H)
• 440 x 210 x 44mm
Weight
• 2.40 kg
Ventilation
• 2 x Smart Fan
Power Surge Protection
• All Ethernet ports support IEC61000-4-5 6 kV surge protection
Operating Temperature
• -5 to 50 ˚C (23 to 122 ˚F)
Storage Temperature
• -20 to 70˚C (-4 to 158 ˚F)
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
EMI
• CE, FCC, C-Tick, VCCI, BSMI
Safety Certifications
• cUL, CB
1Feature available in a future software
Products | Support  | News  | About |
