DIS-S301SXEOL EOS
1000Base-SX Multi-Mode SFP transceiver (up to 550 m)
Description
The DIS-S301SX Gigabit SFP fiber transceiver is external transceiver designed for insertion in SFP (Small Form-Factor Pluggable) slot of network device for transmission and reception of data signals on the fiber cables. This transceiver provides the Gigabit operation and physical compactness to deliver the speed, reliable long-distance (up to 550 m) data transfer, and deployment fexibility that today’s fiber networks require. The transceiver is able to operate in a wider temperature range (-40 to 85 °C).
The DIS-S301SX transceiver uses standard duplex LC connector for fiber cable connection. It conforms to industry standards and is interoperable with D-Link Gigabit switches. Hot-swap capability allows network administrators to plug or unplug it from the SFP slot without having to turn off the power of the connected device.
General features
Features
Standard
• IEEE 802.3z 1000Base-SX
Wavelength
• 850 nm
Data Rate
• 1.25 Gbps
Connector
• Duplex LC
Fiber Type
• 50/125 um Multi-mode Fiber (up to 550 m)
• 62.5/125 um Multi-mode Fiber (up to 300 m)
Maximum Fiber Cable Length
• 550 m
Transmit Power Range
• -3 to -8 dBm
Receive Power Range
• -3 to -22 dBm
Sensitivity
• -22 dBm
Features
• Hot Pluggable
• MSA Compliant
• RoHS Compliant
Physical Parameters
Power Support
• 3.3 V
Supply Current
• 300 mA
Power Budget
• 14 to 19 dB
Heat Generated
• 1.782 kJ/h
MTBF (hours)
• 224 167
Temperature
• Operating: -40 to 85 В°C
• Storage: -40 to 85 В°C
Humidity
• Operating: 5% to 95%
• Storage: 5% to 95%
Dimensions
• 55.4 mm x 13.7 mm x 8.5 mm
Weight
• 20 g
EMI
• CE
• FCC
• VCCI
Safety
• LVD
• EN 60825-1
• EN 60825-2
Certificates
Order info
DIS-S301SX   1000Base-SX Multi-Mode SFP transceiver (up to 550 m)
Pictures
DIS-S301SX/A
Front view
Downloads
Support Resources
