DE-816TPEOL EOS
16-port 10BASE-T Ethernet Hub
Description
This mounted in a 19 "rack 10Mbps hub for workgroups. Each hub has 16 ports for connecting twisted pair, the number of which can be increased by cascading to another hub.
General features
Data transfer rate
10 Mbps
Protocol
CSMA/CD
EMI Certification
FCC Class B, VCCI II, CE B
AC power
100 - 250 V, 50 - 60 Hz
Power consumption
18 W
Dimensions (including mounting brackets)
483 x 44 x 125 mm
Weight
2.0 kg
Operating temperature
0° - 55° C
Humidity
10 - 90 % non-condensing
Certificates
Order info
DE-816TP 16-port 10BASE-T Ethernet Hub
