Description
Plug-and-Play Workgroups
These switches are designed to enhance workgroups' performance while providing a hight level of flexibility . Powerful yet easy to use, they allow users to simply plug any port to ether a 10Mbps or 100Mbps node to multiply bandwidths boost response time and satisfy heavy load demands.
2 Fiber Links
Witha built-in slot, users can configure the switch with2 fiber ports to establish2 secure, long-distance fiber links between 2 switches or betweena switch anda server . Capable of running at full-duplex, these ports serve well in high EM interference environments, providing cable distances of up to2 km.
2 Uplinks for Easy Expansion
2 MDI uplink ports supporting 10/100Mbps connection are provided, allowing easy cascading to2 other switches to expand the port density. Both uplink ports support full-duplex speed of 200Mbps.
Port Trunks Up to 4 ports can be combined into1 high-bandwidth, full-duplex 800Mbps switch-to-switch or switch-to-server connection.
VLANs for Performance and Security
The switches support up to multiple port-based VLANs to extend the broadcast domain, segment network traffic and improve performance and manageability.
General features
Standards
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE-TX, 100BASE-FX Fast Ethernet
- ANSI/IEEE 802.3 NWay auto-negotiation
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet:
10Mbps (half duplex)
20Mbps (full duplex)
- Fast Ethernet:
100Mbps (half duplex)
200Mbps (full duplex)
Topology
Star
Network Cables
- 10BASE-T:
2-pair UTP Cat. 3, 4, 5 (100 m)
- 10BASE-T, 100BASE-TX:
EIA/TIA-586 100-ohm screened twisted-pair
(STP) (100 m)
- 100BASE-TX:
2-pair UTP Cat. 5 (100 m)
- 100BASE-FX:
62.5/125 micron multimode fiber-optics (2 km)
Number of Ports
- DES-1016: 10/100Mbps port x 16
- DES-1024: 10/100Mbps port x 24
- DES-1016F: 10/100Mbps port x 14, 100BASE-FX port x 2
- DES-1024F: 10/100Mbps port x 22, 100BASE-FX port x 2
Media Interface Exchange
MDI RJ-45 x 2 (shared with 2 10/100Mbps ports)
Twisted-pair Rx Reverse Polarity
- Auto-correction
LED Report
Per device:
- Power
Per port:
- 100Mbps speeds
- Full duplex
- Link/activity
Transmission Method
- Store-and-forward
Filtering Address Table
- 1K entries per device
MAC Address Learning
- Automatic update
- Max Age: fixed
Packet Filtering Rates
- 10BASE-T: 14,880 pps per port (half-duplex)
- 100BASE-TX, 100BASE-FX: 148,800 pps per port (half-duplex)
Packet Forwarding Rates
- 100BASE-TX/100BASE-FX: 148,800 pps per port (half-duplex)
RAM Buffer
- 3MB per device
- Dynamic allocation for each port
Port Trunks
Number of Ports per Trunk
Up to 4 ports (800Mbps at full-duplex)
VLAN
Number of Ports per VLAN
- 16-port switches: 16 ports max.
- 24-port switches: 24 ports max.
Number of VLANs per Switch
- Up to switch's total number of ports
- Port overlapping in different VLANs permitted
Certificates
Order info
Ethernet/Fast Ethernet Switches
DES-1024 24 auto-sensing 10/100Mbps ports
DES-1024F 22 auto-sensing 10/100Mbps ports, 2 100BASE-FX fiber ports
