Quick find
Product features:
24-Port 10/100 RJ21 Module For DES-6500 Chassis
General features:
Standards
- IEEE 802.3 10BASE-T
- IEEE 802.3u 100BASE-TX
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
Protocol
CSMA/CD
Topology
Star
Data Transfer Rates
- Ethernet:
  10Mbps (half duplex)
  20Mbps (full duplex)
- Fast Ethernet:
  100Mbps (half duplex)
  200Mbps (full duplex)
Network Cable
Ethernet Cat. 5 cable (max. 100 m)
Number of Ports
24 10/100BASE-TX Ethernet ports
Connectors
2 RJ-21 connectors, each supports 12 Ethernet ports
AC Input
90 to 264 VAC, 47/63 Hz
Through DES-6500 chassis switch power supply
Power Consumption
28 watts max.
Operating Temperature
0 to 40 C
Storage Temperature
-25  to 55 C
Humidity
5% to 95% RH, non-condensing
Dimensions
330 mm x 281 mm x 27.5 mm
EMI
- FCC Class A
- CE
- VCCI
- C-Tick
Box Includes
- DES-6510 24-port 10/100BASE-TX module
- Quick Installation Guide
Products | Support  | News  | About |
