Description
The DES-3800 series is a member of the D-Link xStack family of next generation switches T that deliver performance, flexible expansion, robust security, multi-layer Quality of Service (QoS), Power Over Ethernet and redundant power option. The DES-3800 series forms a cost-effective Ethernet virtual stack for workgroup connection. It incorporates L3 packet routing and many functions typically found in a chassis-based solution. The DES-3800 series provides Single IP Management for seamless integration with a core Gigabit xStack attached to an optional high-speed 10Gigabit backbone.
L3 Virtual Stack. Simple to deploy and easy to manage, the DES-3800 series comprises the departmental access-level devices that can be easily stacked and configured with any switches supporting D-Link's Single IP Management, including the D-Link xStack core switches, to form part of a multi-level network structured with backbone and centralized high-speed servers. Without any stacking cable, cable distance barrier and physical stacking method limitations, a DES-3800 stack can comprise of 32 units that are located anywhere on the same network domain, eliminating the possibility of any single point of failure. Ideal for deployment at the network edge, the DES-3800 blends L2 packet switching with dynamic L3 IP routing to relieve the network backbone and servers of any unnecessary traffic.Comprehensive Security.The DES-3800 series provides a complete set of security features for connectivity and access control, which includes L2/3/4 and Packet Content Access Control Lists (ACL), storm control and IP-MAC-Port Binding with DHCP Snooping. Authentication mechanisms such as 802.1x Guest VLAN, Web-based Access Control (WAC) and MAC-based Access Control (MAC) provide extra flexibility for user identity control. The DES-3800 also provides central management for administration access via TACACS+ and RADIUS. In addition, built-in Safeguard Engine protects DES-3800 against abnormal traffic from virus or worm scanning. Together with network application control, this security ensures that not only proper user access is served, but malicious traffic is also prevented from being spread across the network.
Enhanced Network Performance & Availability. The DES-3800 series provides extensive VLAN support including 4K VLAN entries, Q-in-Q, GARP/GVRP and 802.1v Protocol VLAN to enhance network security and performance. Bandwidth control allows users to set traffic limit for each port or flow to control the traffic volume from the edge of the network. The DES-3828, DES-3828P and DES-3852 support redundant power option to maximize network uptime. Other features include 802.3ad Link Aggregation, 802.1d Spanning Tree, 802.1w Rapid Spanning Tree and 802.1s Multiple Spanning Tree and Loopback detection to increase network reliability and availability of a Virtual Stacking network structure.
Multi-layer Quality of Service (QoS). The DES-3800 series implements a robust set of multilayer (L2, L3, L4) QoS/CoS features to ensure that critical network services like VoIP , ERP, Intranet and video conference are served with proper priority. 8 priority queues for 802.1p/TOS/DiffServ are supported, with classification and marking based on MAC SA/DA,IPv4/v6 SA/DA, DSCP, and/or TCP/UDP port numbers. With IP Multicast support, the DES-3800 is also ideal for high-bandwidth applications, such as MPEG video, delivering traffic to multiple receivers without adding any additional traffic burden to the network.
General features
Interface
- 24 10/100BASE-TX Ports
- 2 10/100/1000BASE-T Ports
- 2 Combo 10/100/1000BASE-T Ports/SFP Slots
- Auto-Negotiation of Network Speeds
- RS-232 Console Port
Power
- Internal Power Supply: AC to DC
- Power Input: 100 to 240VAC, 1A, 50 to 60Hz
- Power Consumption: 395.2 watts (max.)
- Optional Redundant Power Supply
- 802.3af Power Over Ethernet
- Number of PoE Capable Ports: 24
- PoE Auto-Discovery
- PoE Auto-Disable (Per Port)
- PoE Active Circuit Protection
Performance
Switching Capacity
12.8Gbps
64-Byte System Packet Forwarding Rate
9.5mpps
IP Routing Table
2K
Packet Buffer Size
16K
Max. Jumbo Frame Size
32MB
MAC Address Table
9KBytes
Diagnostic LED
- 10Mbps or 100Mbps Speed (Per Ethernet Port)
- 10/100Mbps or 1000Mbps Speed (Per Gigabit Port)
- Link/Activity (Per Port)
- Power, Console, RPS (P er Device)
Software Features
Stackability
- Virtual Stacking
- Support D-Link Single IP Management
- Up to 32 Devices per Virtual Stack
L2 Features
- MAC Address Table: 16K
- Flow Control
- 802.3x Flow Control
- HOL Blocking Prevention
- Jumbo Frame up to 9K Bytes
- IGMP Snooping
- IGMP v1/v2/v3 Snooping
- Support 256 Groups
- Host-based IGMP Snooping Fast Leave
- Spanning Tree
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
- Per port / per device BPDU Filtering
- 802.3ad Link Aggregation
- Max. 32 Groups per device / 8 Ports Per Group
- Port Mirroring
- One-to-One
- Many-to-One
- Flow-based Mirroring
- MLD Snooping
- MLD v1/v2 Snooping
- Loopback Detection
VLAN
- VLAN Group
- Max. 4K Static VLAN Group
- Max. 4K Dynamic VLAN Groups
- 802.1Q Tagged VLAN
- GVRP
- Double VLAN (Q-in-Q)
- 802.1v Protocol VLAN
L3 Features Management
- 128 Static Routing Entries
- RIP v1/v2
- OSPF
- Support OSPF v2
- OSPF Passive Interface
- OSPF Equal Cost Route
- 2K Hardware Routing Entries
- 4K Hardware L3 Forwarding Entries
- VRRP
- 64 IP Interfaces
- ARP Proxy
Multicast
- IGMP v1, v2, v3
- DVMRP v3
- PIM-DM
- PIM-SM
- PIM Sparse-Dense Mode
QoS
- Bandwidth Control:
- Port Based (Ingress/Egress, Min. Granularity 64Kbps)
- Flow Based(Ingress/Egress, Min. Granularity 64Kbps)
- 802.1p Class of Service
- 8 Queues
- Queue Handling
- Strict
- Weighted Round Robin (WRR)
- Strict + WRR
- CoS Based on
- Switch Port
- MAC Address
- TOS
- DSCP
- IP Address
- TCP/UDP Port
ACL (Access Control List)
- Up to 800 Access Rules
- ACL Based on Port
- MAC Address
- 802.1p Priority
- VLAN ID
- DSCP
- IPv4/v6 Address
- Protocol Type
- TCP/UDP Port Number
- User Defined Packet Content
- IPv6 Traffic Class
- IPv6 Flow Label
- CPU Interface Filtering
Security
- SSH v1.5/v2
- SSL v2/v3
- Port Security up to 16 MAC Addresses per port
- Broadcast/Multicast/Unicast Storm Control
- Traffic Segmentation
- IP-MAC-Port Binding
- Support 500 Address Binding Entries per Device
- Support ARP/ACL/Auto (DHCP Snooping) Mode
- D-Link Safeguard Engine
- D-Link ZoneDefense
AAA
- 802.1X
Port-Based Access Control
Host-Based Access Control
Dynamic VLAN Assignment
- Web- Base d Acce ss Con trol ( WAC)
Por t-Ba sed Ac cess C ontr ol
- MAC-Based Access Control (MAC)
- Microsoft NAP
- Guest VLAN
- RADIUS Accounting
- RADIUS and T ACACS+ Authentication for Switch Access
- 3-Level User Account
Management
- Web-Based GUI
- Command Line Interface (CLI)
- Telnet Server/Client
- TFTP Client
- SNMP v1, v2c, v3
- SNMP Trap
- RMON v1
Support 1,2,3,9 Groups
- RMON v2
- Support ProbeConfig Group
- BootP/DHCP Client
- DHCP Auto-configuration
- DHCP Relay Option 82
- DHCP Server
- System Log
- Dual Image
- Dual Configuration
- CPU Monitoring
- SNTP
MIB
- RFC 1213 MIB-II
- RFC 1493 Bridge MIB
- RFC 1907 SNMP v2 MIB
- RFC 1757 and 2819 RMON MIB
- RFC 1643, 2358 and 2665 Ether-like MIB
- RFC 2674 802.1p MIB
- RFC 4363 Bridge MIB
- RFC 2233 and 2863 IF MIB
- RFC 2618 RADIUS Authentication Client MIB
- RFC 2620 RADIUS Accounting Client MIB
- RFC 1724 RIP v2 MIB
- RFC 1850 OSPF v2 MIB
- RFC 2096 IP F orwarding Table MIB (CIDR)
- RFC 2787 VRRP MIB
- RFC 2932 IPv4 Multicast Routing MIB
- RFC 2934 PIM MIB for IPv4
- Private MIB
Certificates
Order info
DES-3828P 24-Port 10/100Mbps + 2 Combo 1000BASE-T/SFP + 2 1000BASE-T L3 Managed PoE Switch
Optional SFP Transceivers
DEM-310GT SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 10km, 3.3V
DEM-311GT SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 550m, 3.3V
DEM-312GT2 SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 2km, 3.3V
DEM-314GT SFP transceiver for 1000BASE-LHX, single-mode fiber, max. distance 50km, 3.3V
DEM-315GT SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 80km, 3.3V
DEM-330T SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 10 km, 3.3V , WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-330R SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 10 km, 3.3V , WDM (Tx: 1310 nm, Rx:1550 nm)
DEM-331T SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 40 km, 3.3V , WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-331R SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 40 km, 3.3V , WDM (Tx: 1310 nm, Rx:1550 nm)
DPS-200 60-watt redundant power supply
DPS-600 500-watt redundant power supply
DPS-800 2-slot redundant power supply chassis
DPS-900 8-slot redundant power supply chassis
Management Software
DS-510 D-View 5.1 SNMP Network Management Program
