Quick find
Product features:
Web Smart 24-Port PoE 10/100 + (4) 1000BASE-T Ports + 2 Combo Ports Switch
EOL EOS
General features:
Interface
- 24 (With Per Port 802.3af PoE) 10/100BASE-TX Ports
- 2 10/100/1000BASE-T Ports
- Auto-Negotiation of Network Speed
- Auto-MDI/MDIX
- 2 Combo 10/100/1000BASE-T/SFP
Performance
Switch Fabric
12.8Gbps
Packet Forwarding Rate
9.52Mpps
Packet Buffer
128KB
MAC Address Table
8K Entries
Software Functions
General
L2 Features
- IGMP snooping: supports 64 multicast group
- Default flooding for non-joined multicast traffic
- 802.1D Spanning Tree
- Port trunk (Link Aggregation): up to 6 groups per device, up to
- 8 ports per group
- Port mirroring
VLAN
- 802.1Q VLAN standard (VLAN Tagging)
- Up to 256 static VLAN groups
QoS (Quality of Service)
- 802.1p Priority Queues standard
- Up to 4 queues per port
- Supports WRR mode in queue handling
Security
- 802.1x port-based access control
- Broadcast Storm Control: threshold of 8K, 16K, 32K, 64K,
- 128K, 512K, 1024K, 2048K, 4096K bytes per second
- D-Link Safeguard Engine to protect CPU from broadcast/multicast/unicast flooding
Management
- Web-based GUI or SmartConsole Utility
- SNMP support
- DHCP client
- Trap setting for destination IP, system events, fiber port events, twisted-pair port events
- Port access control
- Web-based configuration backup/restoration
- Web-based firmware backup/upload
- Firmware upgrade using SmartConsole Utility
- Reboot
MIB
- RFC 1213 MIB-II
- D-Link Enterprise Private MIB
Suppied PoE Power Per Port
15.4 Watts
Total Suppied PoE Power Per Device
170 Watts
Power Supply
100 to 120VAC, 200 to 240VAC, 50/60Hz, Internal Power Supply
Power Consumption (Max.)
222 Watts
BTU/Hr.
757.51
Ventilation
4  40 x 40mm DC Fans
Dimensions
440 x 209 x 44 mm (17.32 x 8.23 x 1.73 inches)
Size
19-Inch Rack-Mount Width, 1U Height
Weight
3.20 kg (7.05 lbs)
MTBF
149,676 hrs
Operating Temperature
0 to 40 C (32 F to 104 F)
Storage Temperature
-10 C to 70 C (14 F to 158 F)
Operating Humidity
10% to 90% RH
Storage Humidity
5% to 90% RH
EMI
FCC Class A, CE, VCCI, C-Tick
Safety
cUL
Products | Support  | News  | About |
