DGS-3200-16EOL EOS
14-port 10/100/1000Mbps Managed Layer 2 Switch & 2 combo 1000Mbts/SFP Gigabit ports
Where to buy
Description
The  DGS-3200  series  includes  the  DGS-3200-10  and the  DGS-3200-16  Security  Gigabit  Switches.  These switches  offer  a  new  generation  of  intelligence  and defense  delivered  through  their  high-performance, fexible, and robust security. This switch secures  the network  from viruses using  the ACL,  IMPB  (IP-MAC-Port Binding) and SafeGuard Engine functions.
The DGS-3200-10  is  built with  a  fan-less  technology. The compact, 11-inch switch produces and emits less heat and noise than standard switches.
Mean while,  the  DGS-3200-16  comes  with  smart fan  feature  that  has  heat  sensors  and  a  fan  that maintains  the  temperature of  the device  for optimum performance. To minimize noise  reduction,  the  fan  is switches off by default.
The DGS-3200-10 and DGS-3200-16, compared  to any other model,  are  ideal  for  an  offce  environment  or circumstances that require silence.
Comprehensive Security
The DGS-3200 series offers a complete list of endpoint security  features  to  add  confdence  and  assurance towards  your  network.  It  executes  from  network security  and  comes with  user-based  identity  control by  implementing  host-based  802.1x  authentication/authorization,  along  with  clientless  Web-based Access  Control  (WAC)  and  MAC-based  Access Control (MAC) for easy deployment. The incorporation of  sophisticated  ACL  user-defned*  functionality secures  the  internal  IT  network  against  viruses and worms  from  invading  the  LAN  to  provide  better security.  Innovative  IP-MAC-Port  Binding  prevents ARP spoofng and man-in-middle attacks by disabling users from manually confguring their own IP or MAC address,  and  allowing  administrators  to  assure  that the IP information on the syslog server or frewall log is  correct.  Other  security  features  like  port  security
and  traffc  segmentation  provide  granular  control  to business  environments,  allowing  administrators  to enhance network security. D-Link’s  joint  security  provides  admission  control  and real-time  defense  through  Microsoft’s  NAP  (Network Access  Protection)  and  D-Link’s  ZoneDefense*
respectively. D-Link’s  built-in  ZoneDefense  technology allows businesses to integrate their switch with D-Link’s NetDefend  frewall  to  implement  full  coverage  and  a proactive security architecture.
IPv6 Technology
D-Link’s  DGS-3200  series  embraces  Microsoft Network  Access  Protection  (NAP)  which  supports both IPv4 and IPv6 protocol versions. NAP is a policy
enforcement technology built into the Windows Vista® operating  system  that  allows  customers  to  better protect  network  assets  from  unhealthy  computers by  enforcing  compliance  with  network  health policies. The IPv6 multicast host, the latest in protocol technology, enables maximum hardware performance. Features such as MLD snooping enhance effciency in selective distribution by  forwarding multicast data  to ports  that  receive data,  rather  than fooding all ports in a VLAN. Features such as ACL based on IPv6 fow label and traffc class, as well as QoS-based on IPv6 help  provide  faster  and  an  effcient  service.  Under IPv6 Management, we support Web, telnet and SNMP over IPv6.
Resilience/Performance Enhancement
To enhance network  resilience,  the DGS-3200  series provides  Spanning  Tree  protocols  including  802.1D, 802.1w,  and  802.1s  for  redundant  bridge  paths. 802.3ad  Link  Aggregation  provides  aggregated bandwidth between  switches or  servers  to  increase redundancy  for higher availability. Quality of Service (QoS)  incorporates multilayer  function  that  supports 8  queues  including  802.1p  priority  and  packet classifcation based on TOS, DSCP, MAC, IP, VLAN ID and L4 TCP/UDP ports enabling  Internet voice, video and streaming media applications to run smoothly. The DGS-3200 series also provides a Safeguard Engine for network  protection  to  increase  switch’s  reliability, serviceability and availability.
Traffc Control
Network administrators can defne  throughput  levels for  each  port  to  allocate  its  essential  bandwidth. Broadcast  storm  control  and  fow-based  bandwidth control  can  reduce  the  level  of  damage  from  virus attacks or P2P applications to the network.
Single IP Management
The  DGS-3200  series  simplifes  and  speeds  up  your management  tasks  as  multiple  switches  can  be confgured,  monitored  and  maintained  from  any
workstation  running  a  web  browser  through  one unique  IP  address.  This  virtual  stack  is managed  as a single object, having all units maintained by one IP address.
Manageability
The  DGS-3200  series  supports  standard-based management  protocols  such  as  SNMP,  RMON, Telnet,  Console,  web  GUI  and  SSH/SSL  security authentication.
General features
Device Interfaces
+  14 10/100/1000BASE-T Gigabit Ports
+  2 Combo 10/100/1000BASE-T/SFP Ports
+  RS-232 DB-9 Console Port
Performance
+ MAC Address Table: 8K
+ Switch Capacity: 32Gbps
+ Maximum Packet Forwarding Rate: 23.81Mpps
+ Switching Method: Store and Forward
+ Packet Buffer Memory Size: 128Kbytes
Flow Control
+  802.3x Standard in Full Duplex Mode
+  Back Pressure in Half Duplex Mode
EMI
+  FCC, CE, VCCI Class A, C-Tick
Safety
+ UL, CB Report
SOFTWARE FUNCTIONS
Stackability
+ Virtual Stacking
Support D-Link Single IP Management
Up to 32 devices per virtual stack
L2 Features
+ Flow Control
802.3x Flow Control
HOL Blocking Prevention
+ Jumbo Frame up to 10,240 Bytes
+ IGMP snooping
IGMP v1/v2/v3 Snooping
Support 256 Groups
IGMP Snooping Fast Leave
+ MLD Snooping
MLD v1/v2 Snooping
Support 256 Groups
+ Spanning Tree
802.1D STP
802.1w RSTP
802.1s MSTP
+ Per port / per device BPDU fltering
+ Loopback Detection
+ 802.3ad Link Aggregation
Max. 5 Groups per device/8 Ports per group
+ Port Mirroring
Support One-to-One
Many-to-One
Flow-based Mirroring
VLAN
+ VLAN Group
Max. 4K Static VLAN Groups
Max. 255 Dynamic VLAN Groups
+ 802.1Q Tagged VLAN
+ GVRP
+ 802.1v Protocol VLAN
QoS (Quality of Service)
+ 802.1p Class of Service
+ 8 queues
+ Queue Handling
Strict
Weighted Round Robin (WRR)
+ CoS based on
Switch Port
VLAN ID
802.1p Priority Queues
MAC Address
IPv4/IPv6 Address
DSCP
TCP/UDP Port
Protocol Type
IPv6 Traffc Class
IPv6 Flow Label
User-Defned Packet Content
+ Bandwidth Control
Port-based (Ingress/Egress, min. granularity 512Kb/s)
Flow-based (Ingress, min. granularity 64Kb/s)
ACL (Access Control List)
+ Up to 200 access rules
+ ACL Based on
802.1p Priority
VLAN ID
MAC Address
IPv4/IPv6 Address
DSCP
Protocol Type
TCP/UDP Port Number
IPv6 Traffc Class
IPv6 Flow Label
User Defned Packet Content
+ Time-based ACL
+ CPU Interface Filtering
Security
+ SSH v2
+ SSL v1/v2/v3
+ Port Security: up to 16 MAC address per port
+ Broadcast/Multicast/Unicast Storm Control
+ Traffc Segmentation
+ IP-MAC-Port Binding
Support 128 address binding entries per device
Support ARP / ACL Mode
+ D-Link Safeguard Engine
+ Microsoft
® NAP (Supports IPv4/IPv6)
AAA
+ 802.1X
Port-Based Access Control
Host-Based Access Control
Dynamic VLAN Assignment
+ Web-Based Access Control (WAC)
+ MAC-Based Access Control (MAC)
+ Guest VLAN
+ Authentication for Management Access Support RADIUS/TACACS+
+ RADIUS Accounting
Management
+ Web-based GUI (Supports IPv4/IPv6)
+ Command Line Interface (CLI)
+ Telnet Server/Client (Supports IPv4/IPv6)
+ TFTP Client (Supports IPv4/IPv6)
+ ZModem
+ SNMP v1/v2c/v3
SNMP over IPv6
+ SNMP Trap
+ System Log
+ RMON v1
Support 1,2,3,9 Groups
+ RMON v2
+ Support ProbeConfg Group
+ BootP/DHCP Client
+ DHCP Auto-Confguration
+ DHCP Relay
+ DHCP Relay Option 82
+ Dual Image
+ Dual Confguration
+ CPU Monitoring
+ SNTP
+ ICMPv6
+ IPv6 Neighbor Discovery
MIB/IETF® Standard
+ RFC1213 MIB-II
+ RFC1493 Bridge MIB
+ RFC1907 SNMPv2 MIB
+ RFC1757, 2819 RMON MIB
+ RFC2021,RMONv2 MIB
+ RFC1643,2358,2665 Ether-like MIB
+ RFC2674 802.1p MIB
+ RFC2233, 2863 IF MIB
+ RFC2618 RADIUS Authentication Client MIB
+ RFC2925 Ping & Traceroute MIB
+ D-Link Private MIB
+ RFC768 UDP
+ RFC783 TFTP
+ RFC791 IP
+ RFC792 ICMP
+ RFC793 TCP
+ RFC826 ARP
+ RFC854 Telnet
+ RFC951, 1542 BootP
+ RFC2068 HTTP
+ RFC2138 RADIUS
+ RFC2139,2866 RADIUS Accounting
+ RFC2620, RADIUS Accounting Client MIB
+ RFC1492 TACACS
+ RFC1157 SNMPv1
+ RFC1901, 1908 SNMPv2c
+ RFC2570,2575 SNMPv3
Diagnostic LEDs
+ Per Device: Power, Console
+ Per 10/100/1000BASE-T Port: Link/Activity/Speed
+ Per SFP Slot: Link/Activity/Speed
Power
+ AC Input Power: 100-240 VAC, 50-60 Hz
Dimensions
+  280 (W) x 180 (D) x 43 (H)
Ventilation
+ One Fan (Default off)
Temperature
+ Operating Temperature: 0? ~ 40?C
+ Storage Temperature: -40? ~ 70?C
Humidity
+  5%-95% non-condensing
MTBF
+  354,222 Hours
Power Consumption
+  28.9Watts (Max.)
EMI
Safety
+ UL, CB Report
Certificates
Order info
DGS-3200-16   14 Ethernet 10/100/1000 Ports + 2 combo 10/100/1000Base-T/SFP ports L2 Managed Switch
Pictures
DGS-3200-16
Back view
Front view
Downloads
Support Resources
