DKVM-4K
4-Port PS/2 KVM Switch
Where to buy
Description
The D-Link DKVM-4K 4-port PS/2 KVM switch allows you to manage up to four computers with one monitor, one keyboard and one mouse. The DKVM-4K requires no driver installation and no external power adapter connection. This KVM switch supports hot-plugging - you don't need to turn your computers off before installing the device. The DKVM-4K allows you to switch between computers quickly and easily using the buttons located on the top panel or keyboard hot keys. The  DKVM-4K supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires.
General features
  B A
Hardware
Ports for connecting KVM cables • 4 VGA ports
• 4 VGA ports
• 4 PS/2 ports (keyboard)
• 4 PS/2 ports (mouse)
Ports for connecting management console
• Monitor (local): VGA
• Keyboard (local): PS/2
• Mouse (local): PS/2
KVM cable connectors for connecting PC
• Video: 15-pin HDB connector (blue) (VGA)
• Keyboard: 6-pin mini-DIN connector (purple) (PS/2)
• Mouse: 6-pin mini-DIN connector (green) (PS/2)
LEDs • 4 port LEDs for connected PCs
Buttons • 4 port switching buttons • 1 port switching button
Enclosure
• Plastic
Connected PCs • Up to 4
Autoscan mode
• Yes
Switching between PCs
• Switching buttons on the top panel
• Hot keys
Sound notification of switching
• Yes
Max. resolution • 2048x1536
Dimensions (L x W x H) • 100 x 65 x 25 mm • 178 x 105 x 30,5 mm
Weight • 725 g  • 272 g
Power Supply • From PS/2 keyboard port on PC (no external power adapter required)
Temperature
• Operating: 0° to 50°C
• Storage: -20° to 60°C
Humidity • 0% to 80% non-condensing
Optional Accessories
KVM Cables*
• DKVM-CB/1.2M/B
• DKVM-CB/B
• DKVM-CB3/B
• DKVM-CB5/B
• DKVM-CB/A
• DKVM-CB3/A
• DKVM-CB5/A
*Note: KVM Cables of B hardware version are compatible only with the DKVM-4K KVM switch of B hardware version. KVM Cables of A hardware version are compatible only with the DKVM-4K KVM switch of A hardware version.
Certificates
Order info
DKVM-4K  4-Port PS/2 KVM Switch
Pictures
DKVM-4K/B
Front view
View from the right
Left side view
Вид сверху
DKVM-4K/A
Front view
Back view
Downloads
Support Resources
