Quick find
Product features:
5-port 10/100 switch with one PoE port
EOL EOS
General features:
KEY FEATURES
• Five 10/100 Mbps fast Ethernet ports with one PoE enabled port
• Auto MDI/MDIX Crossover for all ports
• Store-and-forward Switching Scheme
• Full/half-duplex for Ethernet/fast Ethernet Speeds
• IEEE 802.3x flow Control
• Plug-and-play Installation
• Built-in D-Link green Technology
• RoHS Compliant
• IEEE 802.1p QoS (4 Queues, Strict Mode)
SWITCHING CAPACITY
1 gbps
STANDARDS
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX fast Ethernet
• ANSI/IEEE 802.3 NWay Auto-negotiation
• IEEE 802.1p QoS
POE FEATURES
• Supports IEEE 802.3af
• Supplies power to PD: up to 15.4 watts
• Total PoE budget: 15.4 watts
• PoE port count/Average PoE watts
DATA TRANSFER RATES
• Ethernet:
ƒ 10 Mbps (half duplex)
ƒ 20 Mbps (full duplex)
• Fast Ethernet:
100 Mbps (half duplex)
200 Mbps (full duplex)
TOPOLOGY
Star
MEDIA INTERFACE EXCHANGE
Auto MDI/MDIX adjustment for all ports
NETWORK CABLES
• 10BASE-T
• UTP CAT 3/4/5/5e (100 m max.)
• EIA/TIA-586 100-ohm STP (100 m max.)
• 100BASE-TX
• UTP CAT 5/5e (100 m max.)
• EIA/TIA-568 100-ohm STP (100 m max.)
LED INDICATORS
• Per port: Link/Activity/Speed/PoE Status
• Per device: Power/PoE Max
TRANSMISSION METHOD
Store-and-forward
MAC ADDRESS TABLE
2K Entries per device
MAC ADDRESS LEARNING
Automatic update
PACKET FILTERING/FORWARDING RATES
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 pps per port
RAM BUFFER
64 KBytes per device
POWER CONSUMPTION
• Power On (Standby):
DC input: 0.9 watt
AC input: 1.8 watts
• Maximum (PoE Off)
DC input: 2.05 watts
AC input: 2.7 watts
• Maximum (PoE On)
DC input: 17.29 watts
AC input: 20.2 watts
POWER ADAPTER
Switching 48 V/0.5 A Level V power adapter
MTBF
324,616 hours
OPERATING TEMPERATURE
0 to 40 ˚C
STORAGE TEMPERATURE
-40 to 70 ˚C
OPERATING HUMIDITY
0% to 95% RH non-condensing
STORAGE HUMIDITY
DEVICE DIMENSIONS (W x D x H)
140 x 85 x 28 mm
CERTIFICATIONS
• FCC Class B
• ICES-003 Class B
• cUL
Products | Support  | News  | About |
