Description
The DCS-900W wireless Internet camera is designed as a cost-effective security system for home and the small office. This camera connects to an 802.11b wir eless network and an Ethernet network in a building, or to the broadband Internet. Equipped with a built-in Web server and softwar e for multi-camera monitoring and management, this camera provides a complete system for effective surveillance from anywhere at the local site or via the Internet.
Stand-alone System With Integrated Web Server
This Internet camera comes with a built-in CPU and Web server, providing a low-cost solution capable of solving demanding security and home/office monitoring needs. Its integrated Web server eliminates the need to connect the camera to a computer. Once installed, you use the built-in  IP address to gain access to the camera, make changes to camera settings, and view live video.
Web-based Remote Access
For remote security monitoring, you can install your camera at your home or the office, then view the images from anywhere via a computer running Internet Explorer or Netscape. Directly connected to the Internet without going through any computer, this camera is simple to install and
can easily integrate with your network environment.
Motion Detected Recording
Instead of recording 24 hours a day, 7 days a week, images can also be recorded only when motions are detected. This saves your disk space and eliminates the time wasted to view unnecessary images. Images can be directly archived straight to your computer hard drive or to a Network Attached Storage.
Multi-Camera Monitoring
Surveillance software, called "IPView Lite", is included to let you view up to 4 cameras on a single computer screen at one central location. Images can be recorded to your computer's hard drive manually or according to a pre-set schedule.
High-Quality Video
The DCS-900 supports video resolutions at up to 640 x 480 dpi. The camera uses M-JPEG to stream live video at up to 20 frames per second for real-time viewing.
802.11b Wireless LAN and Ethernet Connection
The DCS-900W is equipped with dual LAN interfaces: an 802.11b wireless LAN interface and a 10/100BASE-TX Fast Ethernet interface. This allows you to connect the camera to both a wireless network and a wired network at home or in a building, and to broadband Internet (via a home gateway router).
General features
Camera Specifications
- 24-bit RGB, 640 x 480 resolution
- 1/3-inch color CMOS sensor, interlace scan mode
- Operating System: RTOS (real-time O.S.)
- Automatic Gain control (AGC) support
- Automatic Exposure (AE) support
- Automatic white balance support
- Signal/noise ratio: 56dB
- Lens mounting: fixed lens
Image (Video Setting)
- Motion-JPEG compression
- Compression ratio: 5 levels
- Maximum image frame rate: 20fps
- Adjustable image size, quality and bit-rate
- Time stamp and text overlay
Communication
- RJ-45 auto-sensing port to connect to 10/100Mbps Ethernet
- Supported communication protocols: HTTP, FTP, SMTP, DHCP, NTP, DNS, DDNS
System Requirement (for Viewing)
- Internet Explorer 5.x or above
- Netscape 6.0 or above
Security
- Administrator and user group protection
- 8-digit password authentication
Led Indicators
- Power
- Activity
Management and Software Update
- Configuration and system log access via Web browser
- Firmware upgrade via TCP/IP
- Reset button
Built-in 802.11b Wireless LAN
Data Rates (Auto Scaling)
- 11 Mbps
- 5.5 Mbps
- 2 Mbps
- 1 Mbps
Modulation Technology (RF)
Direct Sequence Spread Spectrum (DSSS)
Operating Frequency
2.4 - 2.4835 GHz ISM band
Operating Channels
- North America (FCC): 11
- Canada (DOC): 11
- Europe (ETSI): 13
Receiver Sensitivity
@ 8% PER (Packet Error Rate)
- 11Mbps: -81dBm
- 5.5Mbps: -83dBm
- 2Mbps: -86dBm
- 1Mbps: -88dBm
Transmit Output Power
20dBm (typical)
Data Security
64/128-bit WEP (Wired Equivalent Privacy) encryption
Antenna
Dipole detachable antenna (reserve SMA connector)
Operating Range (Open Environment)
- Indoors: Up to 100 meters (328 feet) *
- Outdoors: Up to 300 meters (984 feet) *
* Environmental factors may adversely affect operating range
Certificates
Order info
DCS-900W Internet Camera (with 802.11b wireless LAN and 10/100BASE-TX interface)
