DCS-3710EOL EOS
Megapixel Day & Night WDR Network camera
Where to buy
Description
High resolution Surveillance
The D-link DCS-3710 is a high-end Megapixel Day & Night WDR Network Camera, equipped with a 1/3” Megapixel WDR progressive Scan CMOS and a 2.8~12 mm DC auto iris lens. The DCS-3710 captures video in both dark and light environments, or even subjects shot against a backlight by neutralizing and generating a realistic image. In addition, the removable IR-cut filter for day/night functionality provides clear details and high quality video at any hour of the day. The DCS-3710 incorporates power over Ethernet (PoE) and an SD card slot. Consequently, it can be easily installed in a variety of locations.
Multiple video streams
The DCS-3710 supports simultaneous streaming of MPEG-4 and MJPEG video to provide both high-quality, and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which required high image detail. Mpeg-4 produces a small file size, making it more useful for extended recording or for use in low bandwidth networks. Additionally, the DCS-3710 supports multicast MPEG-4 streaming allowing users to view contact by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-3710 include input and output ports allowing connectivity to external devices such as IR sensors, switches, and alarm relays. It also comes with a RS-485 interface, providing connectivity to an optional pan/tilt enclosure, which effectively adds pan/tilt functionality to the DCS-3710. Additionally, a 12 V interface provides power for an optional LED illuminator.
Wide dynamic range (WDR) applications
the Wide Dynamic Range (WDR) function of a camera provides clear images even under backlit conditions where the intensity of illumination can vary significantly. the DCS-3710 is recommended for extreme high-contrast environments. For example, when placed indoors, the DCS-3710 will adjust itself to the intense sunlight that may be streaming in through a nearby window. this makes it an ideal solution for security applications.
General features
General Specification
• 1/3” Megapixel WDR progressive Scan CMOS
• Removable IR-cut Filter: Auto/Schedule/Manual
• 3A Control: AGC, AWB, AES
• DC iris Vari-focal lens: 2.8~12 mm, F1.3
• Min illumination:
• Color 0.3 lux, B/W: 0.02 lux
• WDR SN ratio: 100 db
Audio
• Two-way audio
• External audio in
• External audio out
• G.726 Codec
Video algorithms supported
• Simultaneous dual stream supports (MPEG and MJPEG)
• Simultaneous profile support for web viewing, 3g mobile viewing, and video recording
• Jpeg compression for still images
Video resolution
• Supported resolutions: 1280 x 960 / 1280 x 720 / 640x480 / 320x240 / 160x120
• Up to 30 fps to all resolutions
Network connectivity
• 802.3af power over Ethernet (PoE)
• 10/100 Mbps Fast Ethernet auto Negotiation
I/O connector
• 4-pin auto iris lens connector
• Di x 2
• Do x 1
• RS-485
• 12 V DC, 200 mA Output
• SD Slot
Security
• Administrator and user group protected
• Password authentication
Remote management
• Camera confiscation and camera system log
• Take snapshots and save to hard drive via a web browser
• D-ViewCam™
Networking protocols
• IPv4, DHCP , ARP , DNS, TCP/IP , DDNS (D-LINK), HTTP , HTTPS, UPNP™ Port Forwarding
• SAMBA, SMTP , PPPOE, NTP (D-LINK), FTP, RTP , RTSP , UDP , RTCP , ICMP , 3GPP
System requirements for viewing
• Internet explorer v6.0 or later
System requirements to run D-ViewCam™
• Operating System: Windows Vista ®, Microsoft Windows ® XP
• Web browser: Internet Explorer v6.0 or later
• Protocol: Standard TCP/IP
Power input
100-240 VAC, 50/60 HZ, 12 V DC 1.25 A
Dimensions (W x D x h)
88 x 53 x 194 mm
Operating temperature
0˚~40˚ C (32˚-104˚ F)
Storage temperature
-20˚~70˚ C (-4˚-158˚ F)
Humidity
20%-80% Non-condensing
Certification
• CE (Class A)
• C-Tick (Class A)
• FCC (Class A)
Certificates
Order info
DCS-3710   Megapixel Day & Night WDR Network camera
Pictures
DCS-3710
Back view
Front view
Downloads
Support Resources
