Quick find
Product features:
7" Outdoor Dome Housing (PoE)
EOL EOS
Description:
D-Link’s DCS-71 outdoor dome housing series provide cost-effective protection and versatile connectivity options for D-Link motorized pan and tilt surveillance cameras in outdoor environments. The DCS-71P model facilitates Power over Ethernet (PoE) while the DCS-71W provides wireless connection for the security camera, providing extra convenience in connecting and wiring surveillance cameras. A built-in power supply, heater and blower mean these housings can be used under adverse weather conditions.
Flexible Connectivity Options
The DCS-71P incorporates Power over Ethernet (PoE) in which electric power is transmitted over an Ethernet cable along with the Ethernet data. This allows the DCS-71P model to be easily installed in a variety of locations without the need for power cabling. The DCS-71W is equipped with wireless antennas that allow the camera to be controlled and monitored wirelessly. This avoids the need to install Ethernet wiring.
Weather-proof
Designed to be mounted outdoors, the DCS-71 housings feature an IP66 certified enclosure which protects against the elements including dust and heavy jets of water.
Products | Support  | News  | About |
