DCS-3010
HD PoE Fixed Network Camera
Where to buy
Description
The D-Link DCS-3010 is a full-featured entry level HD PoE Fixed Network Camera, equipped with 1/4” Megapixel Progressive Scan CMOS sensor and a 4mm iris lens. The camera can capture HD video at resolutions of up to 1280 x 800 with frame rates up to 30 fps. Snapshots and video can be saved to a network drive, or to onboard (optional) storage with the built-in microSD Card slot.
High Definition Surveillance
The DCS-3010 is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This gives you sharp, high-resolution snapshots and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera’s video so you can survey a large area easily. A Power over Ethernet (PoE) port allows you to connect the camera to your network and power it through a single cable, simplifying deployment and doing away with the need for a nearby power outlet.
Multiple Video Streams
The DCS-3010 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. Additionally, the DCS-3010 supports multicast H.264 and MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
A Complete, Expandable Surveillance Solution
The DCS-3010 is a self-sufficient surveillance solution, capable of recording snapshots and video to a microSD card without requiring a PC or network storage device.* If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
* microSD card not included.
General features
Camera Hardware Profile
• 1/4” 1 Megapixel CMOS sensor
• 256 Mbytes SDRAM
• 32 Mbytes of flash memory
• 4mm fixed lens
• Aperture F1.5
• Field of view:
• 56.9° (H)
• 35.9° (V)
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• 3 configurable motion detection windows
• 5 configurable privacy mask zones
• Configurable brightness, saturation, contrast, and sharpness
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 fps recording*
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144 up to 30 fps recording*
Audio Support
• GSM-AMR speech encoding, bit rate: 4.75 kbps to 12.2 kbps
• G.711 audio encoding, bit rate: 8 kbps to 64 kbps
• MPEG-4 AAC audio encoding, bit rate: 16 kbps to 128 kbps
External Device Interface
• 10/100 BASE-TX Fast Ethernet port
• Supports 802.3af PoE
• microSD/SDHC card slot
• External Audio input/output
Network Protocols
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP / HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP / RTSP/ RTCP
• IP filtering
• QoS
• CoS
• Multicast
• IGMP
• ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTPS streaming
• HTTP and RTSP digest encryption
• Remote client access control
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Chrome
Event Management
• Motion detection
• Event notification and uploading of snapshots/videoclips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive or NAS via web browser
• Configuration interface accessible via web browser
Mobile Support
• Windows 7/Vista/XP system or mobile phone
• mydlink mobile app for iOS and Android mobile devices
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 7/Vista/XP
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
• Supports all management functions in web interface
Weight
• 165 g
Power
• 12 V DC/0.5 A, 802.3af PoE
Power Consumption
• 4.6 W (12V DC), 6.6W (PoE)
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Dimensions
* Frame rates when streaming video may vary depending on network conditions and method used.
Certificates
Order info
DCS-3010  HD PoE Fixed Network Camera
Pictures
DCS-3010
View from the right
View from the right
Left side view
Left side view
Back view
Downloads
Support Resources
