Quick find
Product features:
Wi-Fi Baby Camera
General features:
Hardware profile camera
• 1/4-inch megapixel progressive CMOS sensor
• IR light illumination distance: 5m
• Minimum illumination: 0 lux with IR LEDs on
• Built-in microphone and speaker
• Digital Zoom
• Tripod screw mount
• Focal length: 3.3mm
• Aperture: F2.2
• Angle of view:
  • 66.18° (H)
  • 35.9° (V)
  • 76.22° (D)
External device interfaces
• 802.11n wireless
• microSDHC card slot**
• Reset button
• Lullaby, Volume Up/Down, Power buttons
• Power port (Micro-USB)
Image features
• Configurable image size
• Time stamp and temperature overlays
Video Compression
• Compression H.264 video
• JPEG for still images
Video Resolution
• 1280x720
• 640x360
Audio support
• AAC
Baby monitoring features
• Sound detection with adjustable sensitivity
• Motion detection with adjustable sensitivity
• Record snapshots and video to microSD card when triggered by motion or sound
• Temperature detection with configurable alert range
• Sends notifications when sound/motion/temperature change is detected
• 2-way audio lets you listen and respond to your child
Mobile App
• mydlink Baby Camera Monitor app available on the App Store® and Google Play™
• Compatible with iPhone and iPad using iOS 5.1.1 or higher
• Compatible with Android smartphones and tablets using Android 4.01 or higher
Network protocols
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• HTTP
• HTTPS (for configuration)
• UPnP Port Forwarding
• RTP/RTSP/RTCP
Security
• Administrator protection
• Password authentication
• HTTP and RTSP authentication
System requirements for the web interface
• Operating System: Microsoft Windows XP, Vista, 7, 8
• Web browser: Internet Explorer version 7 or higher, Firefox, Chrome, Safari
Measurements
• 137.1 x 92 x 105.5mm with temperature sensor fully extended
Weight
• Device: 139.6g
Power input
• 5VDC/1.5A, 50/60Hz through power adapter
• Can be powered by an external USB battery with at least output 2A output
Power consumption
• 7.5W max.
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• CE
• CE LVD
• FCC
• C-Tick
* USB battery not included, requires at least 2 A output.
** A SDHC Class 6 or above is recommended. Supports card capabilities up to 32GB.
Products | Support  | News  | About |
