DCS-920EOL EOS
WIRELESS INTERNET CAMERA
Where to buy
Description
DUCT DESCRIPTION
The DCS-910/920 is a versatile and unique surveillance solution for your small offce or home.  Unlike a standard webcam, the DCS-910/920 is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance.  The DCS-910/920 can be accessed remotely and controlled from any PC or notebook over the local network or through the Internet via a web browser.  The simple installation and intuitive web-based interface offer easy integration with your Ethernet/Fast Ethernet or 802.11g wireless network.  The DCS-910/920 also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
WIRELESS G CONNECTIVITY
The DCS-920 offers both 802.11g wireless and Ethernet/Fast Ethernet connectivity, making the DCS-920 easy to integrate into your existing network environment.  The DCS-920 works with a 10Mbps Ethernet based network or a 100Mbps Fast Ethernet based network for traditional wired environments and works with 802.11g routers or access points for added fexibility.  The Site Survey feature also allows you to view and connect to nearby wireless networks.
General features
OS SUPPORT
Device
+  Windows 2000 / Windows XP / Windows Vista / Linux/ MAC OS X10.3 or above
Utility
NETWORKING PROTOCOL
+  IPV4, ARP, TCP, UDP, ICMP
+  DHCP Client
+  NTP Client
+  DNS Client
+  DDNS Client
+  SMTP Client
+  FTP Client
+  HTTP Server
+  PPPoE
BUILT-IN NETWORK INTERFACE
+  10/100BASE-TX Fast Ethernet
+  802.11b/g WLAN
WIRELESS CONNECTIVITY
802.11b/g Wireless with WEP/WPA/WPA2 security
WIRELESS TRANSMIT OUTPUT POWER
16dbm for 11b, 12dbm for 11g (typical)
WIRELESS RECEIVER  SENSITIVITY
  (11g Packet Error Rate < 10%)
+  54Mbps: <-66dbm
  (11b Packet Error Rate <8%)
+  11Mbps: < -82dbm
VIDEO CODEC
MJPEG
SENSOR
VGA ¼ inch CMOS Sensor
SDRAM
8 Mbytes
FLASH MEMORY
2 Mbytes
RESET BUTTON
Reset to factory default
VIDEO ALGORITHM SUPPORTED
+  MJPEG
+  JPEG for still image
VIDEO FEATURES
+  Adjustable image size and quality
+  Time stamp and text overlay
+  Flip and Mirror
RESOLUTION
+  640 x 480 at up to 15fps
+  320 x 240 at up to 30fps
+  160 x 120 at up to 30fps
LUX
1 lux@F2.8
3A CONTROL
+  AGC (Auto Gain Control)
+  AWB (Auto White Balance)
+  AES (Auto Electronic Shutter)
Power
+  Input: 100-240VAC, 50/60Hz
+  Output: 5VDC, 2.5A
+  External AC-to-DC Switching Power Adapter
DIMENSION (WxDxH)
71.9mm x 110.0mm x 37mm (without bracket and stand)
WEIGHT
251g (without bracket and stand)
MAX POWER CONSUMPTION
4.25W
OPERATION TEMPERATURE
0˚ to 40˚C (32˚ to 104˚F)
STORAGE TEMPERATURE
- 20˚ to 70˚C (-4˚ to 158˚F)
HUMIDITY
20-80% RH non-condensing
EMISSION (EMI), SAFETY & OTHER CERTIFICATIONS
+  FCC Class B
+  IC
+  C-Tick
+  CE
Certificates
Order info
DCS-920   802.11g Wireless Internet Camera
Pictures
DCS-920
Back view
Front view
Downloads
Support Resources
