DCS-5610EOL EOS
PoE PTZ IP CAMERA
Where to buy
Description
POWERFUL SURVEILLANCE
IP surveillance systems are quickly gaining over conventional CCTV security cameras due to superior performance and low costs. The DCS-5610 now features a Sony VGA Progressive Scan CCD technology which provides exceptional picture quality. Use D-Link's SoC (system-on-chip) products to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. DCS-5610 supports simultaneous dual-streaming for live monitoring and recording. With a built-in Samba client for NAS, DCS-5610 IP camera does not need a direct connection to a PC or any other hardware or software to capture and transfer images.
WIRED PoE ACCESS
For effective surveillance in and around a building, this camera comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module, which eases the installation process and also gives you the freedom to place the camera where it's needed. In addition, a 10/100BASE-TX Ethernet port is also provided for convenient connection to an Ethernet network or to a broadband Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network.
SHARP IMAGE MONITORING FROM DIFFERENT ANGLES
Equipped with a light sensitive lens, this camera is capable of capturing video in rooms with minimal lighting. It features a motorized pan/tilt capability, allowing images to be monitored from different angles, and an optical zoom for greater remote viewing options. The DCS-5610 provides high quality real-time videos in MPEG-4 and JPEG compression with VGA/QVGA/QQVGA resolution delivering 30 frames per second, including the transmission of audio data. DCS-5610 supports Netscape, Mozilla and Opera browser (QuickTime for MPEG4 stream).
VIEW LIVE VIDEO FROM A 3G MOBILE PHONE2
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. Anywhere within the 3GPP service area, users are offered a flexible and convenient way to remotely monitor a home or office in real time.
SMART & EASY TO USE
Records images 24 hours a day, 7 days a week to a computer’s hard drive only when motions are detected. This saves disk space and eliminates the time wasted to view unnecessary images. Also, images can be recorded manually or according to a pre-set schedule. Playback consumes little time with triggered event browsing and fast database searching. The software, D-View Cam allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts to be instantly informed of unusual activities. The camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/ME/Vista to automatically recognize the camera and adds it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP address.
General features
NETWORK PROTOCOL SUPPORT
+ TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, ICMP, Samba client
BUILT-IN NETWORK INTERFACES
+ 10/100BASE-TX Ethernet port
VIDEO ALGORITHM SUPPORT
+ JPEG for still image
+ Enhanced video compression using MPEG4 Simple Profile
+ MPEG4/MJPEG dual format compression
VIDEO RESOLUTION
+ Up to 30fps at 176 x 144
+ Up to 30fps at 320 x 240
+ Up to 30fps at 640 x 480
VIDEO FEATURES
+ Adjustable image size and quality
+ Time stamp and text overlays
+ 3 configurable motion detection windows
+ Flip & mirror
VIDEO BIT RATE
+ 20K to 4M
CAMERA SPECIFICATIONS
+ Sony Progressive Color CCD Sensor
+ 1 Lux @ F1.9
+ AGC/AWB/AES
+ Electronic shutter: 1/60 to 1/15000 sec.
+ Lens: 2.8~7.3mm, F1.9~200
+ 35.8˚~92.2˚ field of view
PAN/TILT/ZOOM
+ Pan range: +/- 150˚
+ Tilt Range: +90˚ to -45˚
+ Optical Zoom: 2.6x
+ Digital zoom: 4x
LAN
+ IEEE 802.3 compliance
+ i EEE 802.3u compliance
+ Support Full-Duplex operations
+ 802.3x Flow Control support for Full-Duplex mode
+ Supported IEEE 802.3af standard (PoE)
PHYSICAL & ENVIRONMENTAL
DIAGNOSTIC LED
2 color LED
POWER INPUT
+ 12VDC 1.5A
+ Through 100 to 240 VAC 50/60Hz 0.4A external power adapter
POWER CONSUMPTION
6W
DIMENSIONS (mm)
104(H) X 103.5 (W) X 118 (D)
WEIGHT
319 gm
AUDIO
+ GSM-AMR/MPEG-4 AAC
+ Supports Audio mute
MICROPHONE
+ Directivity: omni-directional
+ Frequency:50 to 16000Hz
+ S/N ratio: more than 58dB
SECURITY
+ Administrator and user group protected
+ Password authentication
SURVEILLANCE SOFTWARE FUNCTIONS
+ Remote management/control of up to 32 cameras
+ Viewing of up to 32 cameras on one screen
+ Supports all management functions provided in web interface
+ Scheduled motion triggered, or manual recording options
REMOTE MANAGEMENT
+ Configuration accessible via web browser
+ Take snapshots/video clips and save to local hard drive or
remote server via web browser
SURVEILLANCE
(Motion detection weekly schedule)
+ Upload snapshots/video clips via email
+ Upload snapshots/video clips via FTP
SYSTEM REQUIREMENTS
+ Operating System: Microsoft Windows 2000, XP, Vista
+ Browser: Internet Explorer, Firefox, Netscape, Mozilla, Opera browser
SUPPORTED PDA, MOBILE PHONES & SOFTWARE
+ Handsets with 3GPP player
+ Packet Video Player 3.0
+ QuickTime 6.5
+ Real Player 10.5
+ Windows 2000, XP
OPERATION TEMPERATURE
0º to 40º C (32º to 104º F)
STORAGE TEMPERATURE
-20º to 70º C (-4º to 158º F)
HUMIDITY
20% to 80% non-condensing
EMISSION (EMI), SAFETY & OTHER CERTIFICATIONS
+ FCC Class B
+ CE
+ C-Tick
PACKAGE INCLUDES
+ DCS-5610 camera
+ External power adapter
+ Cat. 5 Ethernet cable
+ Quick Installation Guide
+ Master CD
+ Camera stand
Certificates
Order info
Pictures
DCS-5610
Front view
Downloads
Support Resources
