DUB-H7EOL
7-Port USB 2.0 Hub
Where to buy
Description
D-Link’s DUB-H7 7-Port USB 2.0 Hub provides an easy way to add seven USB 2.0 ports to your notebook or desktop computer. In Fast Charge Mode, the hub’s two black ports provide an increased charging current of 1.2 A to effectively charge high-capacity batteries like that of the iPad®. This means you can charge devices like iPads while also connecting additional USB devices like digital cameras, hard drives, mice, keyboards, printers, scanners, and many other peripherals.
Add Seven USB 2.0 Ports to Your Computer
With the DUB-H7 7-Port USB 2.0 Hub, you can conveniently add more USB 2.0 ports to any computer. Now you can connect up to seven more USB peripheral devices – such as digital cameras, printers, external hard drives, mice, keyboards, flash drives, and tablet computers – to your notebook or desktop computer. USB 2.0 technology supports data rates of up to 480 Mbps, which means that you can enjoy faster transfer speeds compared to previous USB standards.
Fast-Charge Your Devices*
The DUB-H7 features two black Fast-Charge ports that are designed to provide an increased charging current of 1.2 A to connected devices when the DUB-H7 is in Fast Charge Mode. This makes it perfect for charging power-hungry mobile  devices like the iPad, as these devices have high-capacity batteries that require higher charging currents to recharge quickly and effectively. The DUB-H7 does not require a PC to charge your devices, so you can take it with you on the road and leave your mobile device chargers at home.
Sync and Charge Your iPad at the Same Time
Normally, when syncing an iPad with a PC, you cannot charge the iPad at the same time. The DUB-H7 lets you do both, allowing you to back up your iPad while giving it a full charge at the same time. Simply install the Windows utility available on the D-Link website to enable your DUB-H7 to sync and charge simultaneously**.
Plug and Play
Simply plug in the power adapter and connect the DUB-H7 to any PC. It’s that easy - no drivers or software installation is required. Now you can connect up to seven additional USB devices to your laptop, notebook, or desktop computer.
Take It with You Anywhere
The DUB-H7 is designed to fit into any notebook bag, and the compact size of the device will allow you to conveniently carry it with you wherever you go. Experience the freedom and convenience of portability and expandability with the D-Link DUB-H7 7-Port USB 2.0 Hub.
*Fast Charge Mode available when connected to a Windows PC with utility installed, or when not connected to a PC.
**It is recommended that the total combined power draw not exceed 2.4 A or 12 W.
General features
  C1   D1
Standards
• USB specification version 2.0 (data rates of up to 480 Mbps)
• USB specification version 1.1 (data rates of up to 12 Mbps)
• OHCI
• UHIC
• EHCI
Interfaces
• Five USB Type A (female) downstream ports, white
• Two USB Type A (female) downstream Fast Charge ports*, black
• Upstream USB Type B port
• Seven USB Type A (female) downstream Fast Charge ports*, white
• Upstream USB Type B (female) port
Connectivity Rules
• Up to 127 devices
• Up to five cascaded hubs
Minimum System Requirements
• Windows 10 / 8 / 7 / Vista / XP
• Mac OS X 10.3 or above
• Linux
Diagnostic LEDs
• Standard Mode (blue)
• Fast Charge Mode (green)
Supplied Charging Current** • Standard Mode:
 - 500 mA total for all seven front ports
• Fast Charge Mode*:
- 500 mA each for white ports
- 1.2 A each for Fast Charge ports
• Standard Mode:
- Max. 1.5 A each for Battery Charging 1.2 compliant devices
- Max. 2.4 A each for iPad / iPhone
Power Input • 5 V / 3 A DC
Temperature • Operating: 0° to 40°C
• Storage: -20° to 70°C
• Storage: -20° to 60°C
Humidity
• Storage: 5% to 95% non-condensing
Dimensions (L x W x H)
• 100 x 57 x 23 mm (3.94 x 2.2 x 0.9 inches) • 99 x 57 x 25 mm (3.94 x 2.2 x 0.9 inches)
Weight • 85 g (0.19 lbs)
Certifications
• FCC
• CE
• C-Tick
• VCCI
• IC
• RoHS
• FCC
• CE
• C-Tick
• IC
 • RoHS
Certificates
Order info
Pictures
DUB-H7/Cx
Front view
Back view
View from the right
DUB-H7/Dx
Back view
Front view
View from the right
Downloads
Support Resources
