DHP-346AV
PowerLine AV 4-Port Switch
Description
	Expand your home network
	D-Link’s DHP-346AV PowerLine AV 4-Port Switch uses the HomePlug AV standard for a fast and easy way to expand your network to all corners of your home. HomePlug AV offers speeds of up to 200 Mbps*, making it an ideal solution for fast Internet access, lag-free gaming, streaming video, and Voice over
	IP (VoIP). This router includes four Fast Ethernet ports and a Simple Connect Button for establishing a secure PowerLine network connection in just a few seconds.
	Enjoy convenient stup and secure operation
	Port-based QoS simplifies the process of setting up a high-performance network. You can easily ensure the performance of devices which require the highest quality of service for gaming, VoiP, and multimedia applications. Plug these high performance devices into the high-priority Ethernet ports, and this switch takes care of the configuration for you. The security of your data is ensured through AES data encryption which protects the PowerLine network from intruder wire-tapping.
	Save energy with D-Link Green
	D-link Green features for the DHP-346AV include PLC (Power Line Communication) power saving and power saving by link status. PLC power saving shuts down the PowerLine function when no Ethernet activity is detected. Power saving by link status automatically detects the link status of wired devices and reduces the power usage of ports that are idle.
General features
	Minimum System Requirements
	• Windows, Macintosh, or Linux-based operating system
	• Ethernet adapter
	Ports
	• 4 x 10/100 Mbps Ethernet LAN (RJ-45)
	Data Rates
	• HomePlug AV: up to 200 Mbps*
	LED Status Indicators
	• Power
	• Ethernet
	• PowerLine
	Interface
	• Simple Connect Button
Certificates
Order info
