Quick find
Product features:
AirPremier N Dual Band Exterior Access Point
EOL
General features:
Standards
+  IEEE 802.11a/b/g WLAN
+  IEEE 802.11n (draft) WLAN
+  IEEE 802.3/802.3u Ethernet
+  IEEE 802.3x Flow Control (for Ethernet)
Ethernet Interface
+  10/100/1000 BASE-TX Ethernet port  with 802.3af PoE and auto-MDI/MDIX support
Operating Frequency
For 802.11a:
    +  5150 to 5350MHz
    +  5470 to 5725MHz
    +  5725 to 5850MHz (for Europe)
For 802.11b:
    +  2400 to 2497MHz
For 802.11g:
    +  2400 to 2483.5MHz
For 802.11n (draft):
    +  2400 to 2483.5MHz (2.4 GHz band)
    +  5150 to 5825MHz (5 GHz band)
Channel Numbers
+  11 Channels (FCC)
+  13 Channels (ETSI)
Maximum Transmit Output Power2
+  18dBm@2.4GHz
+  17dBm@5GHz
Antennas Embedded Dual Band antennas (8dBi for 2.4GHz, 10dBi for 5GHz)
Two RN-P N type connectors for optional antennas4
Security
+  64/128-bit WEP data encryption
+  WPA-PSK, WPA2-PSK
+  WPA-EAP, WPA2-EAP
+  TKIP, AES support
+  MAC address filtering user access
+  WLAN partitioning
+  Multiple SSID for network segmentation
+  SSID broadcast disable function
+  802.1Q VLAN Tagging
+  Rogue AP detection
+   Network Access Protection
Quality of Service
+  Wireless Multimedia (WMM)
Configurable Operation Modes
+  Access Point
+  WDS with AP
+  WDS
+  Wireless Client
Performance Enhancement
+  AP grouping for load balance
Device Management
+  Web Browser Interface:
    - HTTP
    - Secure HTTP (HTTPS)
+  AP Manager II
+  D-View 6.0
+  SNMP support:
    - Private MIB
+  Command Line Interface:
    - Telnet
    - SSH
Diagnostic LEDs
+  Power
+  LAN
+  WLAN
Accessories Provided for Outdoor Installation
+ PoE base unit
+ Ethernet cable (4 meters long)
+ Set of grounding wires
+ Wall mount
+ Pole mount (option) 3
Operating Voltage
48VDC +/- 10% for PoE
Dimensions
+  190 (L) x 160 (W) x 55 (H) mm
Weight
+  774g (Without mounting kit)
Operating Temperature
-20˚ to +60˚ C
Storage Temperature
-20˚ to +65˚ C
Operating Humidity
10% to 90% non-condensing, all-weather enclosure
Regulation Certification
+  FCC Class B
+  CE
+  IP 65
+  C-Tick
+  CSA International
+  Wi-Fi®a/b/g/n
1 300Mbps is the maximum theoretical wireless signal rate when using multiple MIMO antennas (derived from 802.11n draft specifcations). Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffc, building materials and construction, and network overhead lower actual data throughput rate. Environmental conditions will adversely affect wireless signal range.
2 Maximum power setting will vary according to individual country regulations.
3 This device can be mounted on a pole using an optional mounting kit (part number B15900-0033000).
4 Embedded patch antennas will be disabled when optional antennas are connected.
5 IP65 standard means the device is protected from dust and low pressure jets of water from all directions - limited ingress permitted. It is recommended to place this device under a roof.
Products | Support  | News  | About |
