ANT70-1400N
Triple Polarization Dual-Band Outdoor Directional Antenna
Where to buy
Description
D-Link ANT70-1400N Triple Polarization Dual-Band Directional Antenna is an outdoor antenna for connecting 2.4 or 5GHZ wireless LAN over long distances and connection with high-speed 11n. It has three antenna connectors for transmitting three spatial streams.
Point-to-Point Application
The ANT70-1400N is ideal for operating in modes such as point-to-point WDS and others that require a high gain directional antenna. An example application of this antenna is to extend your local area network (LAN) by connecting LANs at two physically separated locations. Alternatively, Wireless Internet Service Provider (WISP) subscribers can also use this antenna to establish a strong connection between their host and to their ISP’s outdoor AP.
Weatherproof Design
The ANT70-1400N features a durable build and a waterproof design which provides complete protection from extreme weather. Furthermore, it is made of corrosion-resistant material, enabling it to withstand harsh outdoor conditions and wind speeds up to 216km/hr and is robust enough to remain outside indefinitely. The ANT70-SP surge protector can be purchased seperately to protect the antenna’s receiver from damaging voltages and other outdoor elements such as lightning.
Flexible Deployment
For ready installation, the ANT70-1400N antenna includes a pole mounting kit, which allows it to be placed on a pole for better wireless coverage. It also comes equipped with an indoor adapter cable fitted with N-type and RP-SMA connectors for easy connection to a host.
General features
Frequency Range
• 2400 MHz to 2500 MHz
• 5150 MHz to 5875 MHz
Peak Gain
• 11dBi (2.4GHz frequency band)
• 12-14dBi (5GHz frequency band)
VSWR
• 2.0 : 1 maximum (2.4GHz frequency band)
• 2.0 : 1 maximum (5GHz frequency band)
Polarization
• Linear
• Vertical
Horizontal Half Power Beam Width (HPBW/ H-PLANE)
• 40º-44º (2.4GHz frequency band)
• 19º-22º (5.1GHz frequency band)
Vertical Half Power Beam Width (HPBW/ V-PLANE)
• 38º-41º (2.4GHz frequency band)
• 25º-31º (5.1GHz frequency band)
Front to Back Ratio
-20dB (max)
Downtilt
Power Handling
• 2.4GHz: 10 W (cw)
• 5GHz: 6 W (cw)
Impedance
50 ohms
Connector
N Jack (x 3)
Extension Cable
50 cm with RP-SMA and N-type connector
Mounting Type
Pole & Wall
Survival Wind Speed
216 km/hr
Operating Temperature
-40°C to +80°C
Operating Humidity
95% @ 55°C
Color
White
Material
ABS, UV resistant
Weight
1.72 kg
Dimensions
360 (L) x 360 (W) x 40 (H) mm
1 Transmission and reception distances can vary according to the transmission speeds. To get maximum signal coverage, make sure there is no obstruction in the signal path between the transmission and reception ends.
2 The transmission distance range depends on the two same spec antennas with default cable loss under free line of sight environment.
Certificates
Order info
Pictures
ANT70-1400N/Ax
Front view
Back view
Downloads
Support Resources
