DWA-126EOL EOS
HIGH-POWER WIRELESS N 150 USB ADAPTER
Description
HIGH-SPEED Wireless NETWORKING
Connect to a high-speed wireless network with the D-Link High-Power Wireless N 150 USB Adapter and enjoy surfing the web, checking e-mail, and chatting with family and friends online. The DWA-126 uses Wireless N technology, which offers increased speed and range over the 802.11g/b standard1 giving you a faster, more reliable wireless connection.
CONNECT SECURELY TO YOUR WIRELESS NETWORK
To protect your data and privacy, the High-Power Wireless N 150 USB Adapter supports WEP, WPA, and WPA2 encryption for connecting to a secure wireless network, keeping your network traffic secure.
ENHANCED WIRELESS RANGE
The High-Power Wireless N 150 USB Adapter provides over 2x the wireless coverage of standard wireless N and reduces dead spots within the wireless range.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup of your USB adapter so you can get connected quickly. Wi-Fi Protected Setup (WPS) sets up a secure wireless connection, so all you have to do is push a button to automatically create a secure wireless connection to your network, doing away with the need for configuring complicated settings.
General features
SYSTEM REQUIREMENTS
Computer with:
• Windows 2000 (SP4), XP (SP2), or Vista (32 or 64-bit) or higher
• CD-ROM drive
• 20MB hard disk space
• Available USB port
STANDARDS
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
FREQUENCY RANGE
2.4GHz to 2.4835GHz
ANTENNA
3dBi detachable Omni directional dipole antenna
SECURITY
• 64/128-bit WEP data encryption
• Wi-Fi Protected Access (WPA/WPA2-PSK, WPA/WPA2-EAP)
• Wi-Fi Protected Setup (WPS)
• PBC/PIN
O.S. SUPPORT
Windows XP/Vista and Windows 7
Certificates
Order info
DWA-126 HIGH-POWER WIRELESS N 150 USB ADAPTER
Pictures
DWA-126/A1
Front view
Downloads
Support Resources
