ANT70-0800/AEOL EOS
Description
D-Link’s ANT70-0800 Dual-Band Omni Directional Antenna is suitable for outdoor installation. It provides a Gain of 8dBi for 2.4GHz band and 10dBi for 5GHz band to give your wireless network an extended operating range. For best performance, users can use an antenna of the same Gain or higher, at the other end of the connection to take advantage of this antenna’s powerful signal transmission1.
Point-to-Multi Point Application
The ANT70-0800 is ideal for operating in modes such as point-to-multi point WDS. An example application of this antenna is to extend your local area network (LAN) by connecting LANs at two physically separated locations. Alternatively, Wireless Internet Service Provider (WISP) subscribers can also use this antenna to establish a strong connection between their host and to their ISP’s outdoor AP.
Weatherproof Design
The ANT70-0800 features a durable build and a waterproof design which provides complete protection from extreme weather. Furthermore, it is made of corrosion-resistant material, enabling it to withstand harsh outdoor conditions and wind speeds up to 216km/hr and is robust enough to remain outside indefinitely.
Flexible Deployment
For ready installation, the ANT70-0800 antenna includes a pole mounting kit, which allows it to be placed on a pole for better wireless coverage. It also comes equipped with an indoor adapter cable fitted with N-type and RP-SMA connectors for easy connection to a host.
General features
Power Handling
5 W (cw)
Impedance
50 ohms
Connector
N Jack (built-in)
Extension Cable
N/A
Mounting Type
Pole
Surge Arrestor
Optional
Survival Wind Speed
216 km/hr
Operating Temperature
-40°C to +80°C
Operating Humidity
95% @ 55°C
Color
White
Material
Glass Fiber, UV resistant
Weight
1.03 kg
Dimensions
1220 (L) x 75 (W) x 80 (H) mm
1 Transmission and reception distances can vary according to the transmission speeds. To get maximum signal coverage, make sure there is no obstruction in the signal path between the transmission and reception ends.
2 The transmission distance range depends on the two same spec antennas with default cable loss under free line of sight environment.
