ANT70-CB1N
Antenna Extension Cable with N Plug Connector, 1m
Where to buy
Description
Antenna extension cords ANT70-CB1N and ANT70-CB1RN are used outdoors to connect to external access points D-Link. ANT70-CB1N is equipped with connectors N plug, and ANT70-CB1RN - Connectors RP-N plug and N plug. Cables have low data loss and can operate in two frequency bands - 2.4GHz and 5GHz. Both cables conform dust and moisture protection IP67, which means that they are dust and water tight and waterproof, and can be used in harsh outdoor conditions.
General features
Frequency range
• 2.4~6GHz
VSWR
• 1.7:1 max. at 2.4GHz
• 2.7:1 max. at 5GHz
The insertion loss
• 0.8dB max. at 2.4GHz
• 2dB max. at 5.15~5.85GHz
Resistance
• 50 Ohms
Type of cable
• CFD-200
Cable Length
• 1m
Jack
• N Plug, N Plug
Antenna structure
• Collinear
Temperature
• -40 to 70°C
Humidity
• 95% at 55°C
Dust and moisture protection standard
• IP67
Weight
• 199g
Dimensions
• 1030 x 20.9 x 20.9mm
Certificates
Order info
ANT70-CB1N   Antenna Extension Cable with N Plug Connector, 1m
Pictures
ANT70-CB1N
Front view
Downloads
Support Resources
