CWM-100
Central WiFiManager
Where to buy
Description
Central WiFiManager is D-Link’s latest tool to help network administrators streamline their wireless access point management workflow. Central WiFiManager is an innovative approach to the more traditional hardware-based multiple access point management system and uses a centralized server to both remotely manage and monitor wireless access points on a network. Whether deployed on a local computer or hosted on a public cloud service, Central WiFiManager can be easily integrated into existing networks to help eliminate existing bottlenecks for wireless traffic.
Extendable, Affordable Business Wireless Solution
Designed from the ground up as a standalone software controller, D-Link Central WiFiManager is flexible, robust, and feature rich. It comes ready to run with many enhanced enterprise wireless access point (AP) features to provide a solid wireless network system for customers who need a centralized management controller. Central WiFiManager can be deployed onto a server running Microsoft Windows2 and can manage up to 500 APs3 without an additional license charge. Central WiFiManager currently supports 6 different models of D-Link Access Points1.
Robust Security and Management Tools
Central WiFiManager supports multi-site deployment management as well as multi-tenancy management. This allows network administrators to provide different management authorities between head and regional offices, and allows service providers to offer a managed wireless network for their customers. Sites can be logically separated with their own configuration, access security, network map, and statistics. For example, a network operations manager could pre-configure APs before dispatching them to regional offices. He can then manage all of the APs on an enterprise intranet, while allowing local administrators to manage APs that are only present on their local network. The service provider can simply send a pre-configured AP to a customer and then remotely manage the customer’s wireless network access and security.
For wireless access, D-Link SMB APs can support 8 SSIDs per radio, which means administrators can use one SSID to create a guest network for visitors. Central WiFiManager expands on that built-in feature and allows for multiple user authentications. Access controls can be configured per SSID as well, allowing network administrators to configure separate internal networks for different subnets. This means that more advanced value added services such as a captive portal or Wi-Fi hotspots can be used to help manage wireless network traffic.
Flexible Expansion and Deployment Options
Unlike traditional hardware controller solutions for managing wireless access points, Central WiFiManager has a much lower initial investment cost as it comes bundled with many D-Link access points1 and there are no per access point license charges. With the simple to use installation tool, it is easy to expand the wireless network in the future. Adding devices to Central WiFiManager is done automatically when new access points are discovered on the network, allowing new devices to be quickly managed and deployed. Central WiFiManager also automatically manages RF output for multiple access points, optimizing the number of available wireless channels and coverage. This results in reduced channel interference and provides faster total bandwidth throughput and connection reliability. By optimizing the coverage area and connection quality, Central WiFiManager enables network administrators to provide better wireless service at a lower deployment cost, resulting in a higher return on investment.
Deploying Central WiFiManager is also much simpler compared to traditional hardware controller solutions as it can be installed on any server running a recent version of Microsoft Windows2. Central WiFiManager software operates transparently on the network meaning the access point can be deployed anywhere in a customer’s Layer 2/3 environment. Management traffic to and from the target access points will go through an authorized tunnel to Central WiFiManager while normal network traffic will go through existing networking infrastructure unimpeded. The Central WiFiManager management interface is also remotely accessible via its built-in web server. Administrators can use a web browser to connect to computers with Central WiFiManager installed to manage their WLAN network and wireless access points from anywhere.
1Supported models: DAP-2695, DAP-2660, DAP-2690/B1, DAP-2360/B1, DAP-2330, DAP-2310/B1
2Supported Operating Systems: Microsoft Windows 7 or Windows Server 2008/2012
General features
11ac
Dual-Band
11n
Dual-Band
11n Single-Band
Model
DAP-2695
DAP-2660
DAP-2690
DAP-2360
DAP-2330
DAP-2310
H/W Version
A1
A1
B1
B1
A1
B1
IEEE Standard
802.11a/b/g/n/ac
802.11a/b/g/n/ac
802.11a/b/g/n
802.11b/g/n
802.11b/g/n
802.11b/g/n
2.4 GHz Speed
450 Mbps
300 Mbps
300 Mbps
300 Mbps
300 Mbps
300 Mbps
5 GHz Speed
1300 Mbps
900 Mbps
300 Mbps
Number of SSIDs
16 (8 per radio)
16 (8 per radio)
16 (8 per radio)
8
8
8
Ethernet Interface
2 x Gigabit Ethernet
1 x Gigabit Ethernet
PoE
802.3at
802.3af
802.3af
802.3af
802.3af
802.3af 4
Max Tx Power
27.5 dBm
2.4 GHz: 28 dBm
5 GHz: 26 dBm
23 dBm
26 dBm
28 dBm
26 dBm
Antenna Type
External
Internal
External
External
Internal
External
Antenna Gain
2.4 GHz: 4 dBi
5 GHz: 6 dBi
2.4 GHz: 3 dBi
5 GHz: 4 dBi
2.4 GHz: 4 dBi
5 GHz: 4 dBi
2.4 GHz: 5 dBi
2.4 GHz: 3 dBi
2.4 GHz: 2 dBi
Mounting Type
Wall/Desktop
Ceiling/Wall/ Desktop
Wall/Desktop
Wall/Desktop
Wall/Desktop
Security Lock
Yes
Yes
Yes
Yes
Yes
Yes
Power Adapter
48 V / 0.5 A
12 V / 1A
48 V / 0.5 A
12 V / 1 A
12 V / 1 A
12 V / 1 A
Maximum Power Consumption
18.2 W
11 W
10.67 W
7.9 W
4.8 W
6.5 W
PoE Kit in Package
Yes
No
Yes
No
No
No
Технические характеристики
Maximum APs per Device (Controller)
• 5003
WLAN Management Features
• AP grouping
• Multi-tenancy
• Visualized topology
• NAT pass-through
AP-Controller Connection Mode
• Bridge mode
User Authentication
Guest Portal
• Captive portal
Authentication Method
• Local
• LDAP
• POP3
• Voucher
• RADIUS
Hotspot Features
• Built-in support for voucher-based authentication
• Rate limiting and bandwidth control for guest and guest management
• Built-in hotspot manager for voucher creation and guest management hotspot portal guest management
Wireless features
RF Management and Control
• Auto Output Power Control
• Auto Channel
• Self-healing around failed APs
Multiple SSIDs per Radio(AP)
• 8
Advanced Wireless Features
• Band steering
• L2 roaming
• Bandwidth optimization
WIDS System
• Rogue AP detection
System Management
Management Interface
• Web-based user interface
Minimum System Requirements
• Computer running Microsoft Windows 7 or Windows Server 2008/2012
Online Check
• Firmware
• Module
Scheduling
• Firmware update
• Configuration update
3Number of wireless access points supported depends on the specification of the computer on which Central WiFiManager is installed. To support 500 APs, a computer with at least an Intel Core i5 3.2 GHz with 4 GB RAM and 2 TB hard drive is recommended.
4 PoE support determined by specific part
Certificates
Order info
CWM-100 Central WiFiManager
Pictures
CWM-100
Front view
Front view
Front view
Front view
Downloads
Support Resources
