ANT24-1201
Directional Outdoor Yagi Antenna for 2.4 GHz
Where to buy
Description
Outdoor 8dBi Gain Omni-Directional Antenna
The D-Link ANT24-1201 Directional Yagi High Gain Outdoor Antenna with surge arrestor and N to SMA pigtail 0.5m is ideal for point-to-point environment.
General features
Electrical Specification
•  Frequency range: 2400 MHz - 2500 MHz
• Gain: 12 dBi
• VSWR: 1.5 : 1 Max.
• Polarization: Linear vertical
• HPBW
   - horizontal - 50o
   - vertical - 50o
•  Front to back ratio: 15 dB
• Downtilt: 0o
• Power handling: 50 W (cw)
• Impedance: 50 Ohms
•  Connector: N female or SMA female
Envnironmental & Mechanical Characteristics
• Survival wind speed : 216 km/hr
•  Temperature:  - 40 C to +80 C
•  Humidity: 100% @ 25 C
•  Lightning protection: DC ground
• Radome color: Gray-white
• Radome material
   - ABS/UV resistant
   - Fire retardant
• Weight: 0.3 kgw
•  Dimensions: 280 x 87 x 48 mm
Certificates
Order info
ANT24-1201  Directional Outdoor Yagi Antenna for 2.4 GHz
Pictures
ANT24-1201
Front view
Downloads
Support Resources
