ANT24-1400EOL EOS
Description
D-Link®, an industry leader in networking, introduces the ANT24-1400 14 dBi Directional Panel Antenna designed to provide extended coverage for an existing 802.11b/g wireless network. The directional design of the ANT24-1400 offers dramatically increased wireless signal coverage in a specific direction allowing for improved data throughput at further distances.
	The D-Link ANT24-1400 14dBi Directional Panel Antenna connects to a variety of wireless PCI adapters, wireless routers, and access points on the market today. Whether the wireless router or access point has a SMA or TNC connector, the ANT24-1400 comes with a RP-SMA to RP-TNC conversion adapter to accommodate either connector type.
	The D-Link ANT24-0801 includes a swivel mount that allows pivotal adjustment for precise positioning for the most concentrated signal strength. The D-Link ANT24-1400 also includes a lightning surge protector, and a 0.5m (1.5 feet) cable. The ANT24-1400 is weatherproof and made of corrosion-resistant material to withstand harsh outdoor conditions and wind speeds up to 112 miles/hr (180km/hr).
	Avoid the cost and complexity of adding additional wireless access points or wireless repeaters when you can easily use the ANT24-1400 indoors or outdoors. Enjoy the benefits of wireless connectivity at greater distances and speeds throughout your indoor or outdoor wireless coverage area.
General features
Electrical Specification
	• Frequency range: 2300 MHz - 2500 MHz
	• Gain: 14dBi
	• VSWR: 1.5 : 1 Max.
	• Polarization: Linear, vertical
	• HPBW / horizontal: 30o
	• HPBW / vertical: 30o
	• Front to back ratio: 15 dB
	• Downtilt: 0o
	• Power handling: 50W (cw)
	• Impedance: 50 Ohms
	• Connector: N female
	• Cable: RG-58/U ; 30cm
	Evironmental & Mechanical Characteristics
	• Survival wind speed: 180 km/hr
	• Temperature: - 40o C to +80o C
	• Humidity: 100% @ 25o C
	• Lightning protection: DC ground
	• Radome color: Gray-white
	• Radome material: ABS, UV resistant
	• Weight: 0.825 kgw
	• Dimensions: 240 x 240 x 69.5 mm
Certificates
Order info
ANT24-1400 High Gain Directional Panel Antenna for 2.4 GHz ISM Band
