Quick find
Old model
Product features:
High-Speed 2.4GHz(802.11g) Wireless PCI Adapter
General features:
Wireless Standards
- 802.11g wireless LAN
- 802.11b wireless LAN
Adapter Type
- 32-bit interface PCI Local Bus 2.2 compliant
- Low-profile half-length PCI short card
Media Access Control Protocol
CSMA/CA with ACK
Network Architecture Types
- Ad-hoc mode
- Infrastructure mode
Operating Frequency
2.4 to 2.4835 GHz ISM band
Operating Channels
- FCC: 11
- ETSI: 13
Radio and Modulation Schemes
- 802.11b: DQPSK, DBPSK, DSSS, CCK
- 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
Receive Sensitivity (for 802.11b)
-  84dBm at 11Mbps (8% PER)
-  90dBm at 2Mbps (8% PER)
Receive Sensitivity (for 802.11g)
(1000-byte PDUs 10% PER)
- -87dBm at 6Mbps
- -86dBm at 9Mbps
- -85dBm at 12Mbps
- -83dBm at 18Mbps
- -80dBm at 24Mbps
- -76dBm at 36Mbps
- -71dBm at 48Mbps
- -66dBm at 54Mbps
Transmit Output Power (for 802.11b)
+18dBm at 11Mbps, 5.5Mbps, 2Mbps, and 1Mbps
Transmit Output Power (for 802.11g)
- +12dBm to 16dBm at 54Mbps
- +13dBm to 17dBm at 48Mbps
- +16dBm to 17dBm at 36Mbps
- +17dBm to 19dBm at 24, 18, 12, 9, and 6Mbps
Security
- 64/128/152-bit WEP data encryption
- WPA EAP, WP A PSK
Antenna
Operation Range
- Indoors: up to 100 meters (328 feet) *
- Outdoors: up to 400 meters (1,312 feet) *
* Environmental factors may adversely affect range 2dBi Gain detachable external omni-directional dipole antenna with RP-SMA connector
Physical & Enviromental
Diagnostic LEDs
- Power
- Activity
Operating Voltage
5VDC +/- 10%
Power Consumption
- Transmission: 1650 mW (max.)
- Reception: 950 mW (max.)
- Sleep: 40mW (max.)
Dimensions
120 (L) x 64 (W) x 6 (H) mm
Weight
78 grams
Operating Temperature
0  to 55 C (32 to 131 F)
Storage Temperature
-20 to- 75 C (-4 to 167 F)
Operating Humidity
10% to 90% non-condensing
Storage Humidity
5% to 95% non-condensing
Emission (EMI)
- FCC Class B
- CE
OS Support
Windows 98SE, ME, 2000, XP
Products | Support  | News  | About
