Quick find
Product features:
Wireless N150 Router with 3G/CDMA/WiMAX Support and USB Port
EOL
General features:
MINIMUM SYSTEM REQUIREMENTS
+  Cable or DSL modem with Ethernet port
+  Computer with Windows XP SP2, 2000 SP4 or Mac OS X (v10.4/v10.3) or Linux-based Operating System and an Installed Ethernet adapter
+  Internet Explorer 6 or Firefox 1.5 or later
STANDARDS
+  IEEE 802.11b/g
+  IEEE 802.3, 802.3u
+  USB 2.0
WAN INTERFACE
+  10/100BASE-TX Ethernet port
+  Supports DSL and cable modem connection
+  Supports “Always-on” (bridged) and PPPoE for PPP connection on demand
LAN INTERFACE
+  4 10/100BASE-TX Ethernet ports
+  Support auto MDI/MDIX
+  Support 802.3x fow control (full duplex) and back pressure (half duplex)
USB INTERFACE
+  USB 2.0 Type A port
+  Printer protocols: TCP/IP, RAW printing, LPR
+  Supports Windows Connect Now (WCN) confguration
WIRELESS SIGNAL RATES
(With automatic fallback)
+  54, 48, 36, 24, 18, 12, 11, 9, 6, 5.5, 2, 1Mbps
WIRELESS FREQUENCY RANGE
+  2.4GHz to 2.462GHz
MODULATION TECHNOLGOY
+  Orthogonal Frequency Division
Multiplexing (OFDM)
+ Complementary Code Keying (CCK)
WIRELESS TRANSMIT POWER
+  802.11b: 17dBm +/- 2dBm
+  802.11g: 13dBm +/- 2dBm
ANTENNA
+  Detachable dipole antenna with reverse SMA plug
SECURITY
+  WEP 64/128-bit data encryption  (user-selectable)
+  Wi-Fi Protected Access (WPA/WPA2)
+  WPS (Wi-Fi Protected Setup)
+  Two SSID
+  Guest Zone
FIREWALL FEATURES
+  Network Address Translation (NAT)
+  Stateful Packet Inspection (SPI)
+  MAC Filtering
+  Website URL Filtering
DEVICE MANAGEMENT
+  Web-based management via Internet Explorer v6 or later; or Firefox 1.5 or later browser
DIAGNOSTIC LEDs
+  Power
+  Status
+  Internet
+  WLAN
+  LAN (1 to 4)
+  USB
INPUT POWER
+  Through 5VDC, 2A external power adapter
Dimensions
+  112.6 x 147.5 x 31.8 mm
WEIGHT
+  246 grams (0.5 lb)
CERTIFICATION
+  CE
+  FCC
OPERATING TEMPERATURE
+  0˚ to 40˚ C (32˚ to 104˚ F)
OPERATING HUMIDITY
+  10% to 90% non-condensing
Products | Support  | News  | About |
