ANT24-1202EOL EOS
Description
OPTIMAL PERFORMANCE
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna is designed to be used in conjunction with devices at the 2.4GHz frequency, and compliance with the b and g standards. It offers a powerful omni-directional signal at a high 12dBi gain that can effectively redistribute a wireless signal to multiple remote locations at a wide range from an access point or bridge.
CONVENIENCE OF FLEXIBILITY
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna features a very durable build that grants users with great fexibility. Its waterproof design provides users with the facility of choosing placement in or outdoors. The antenna also includes an N-Type to RP-SMA adapter cable for added compatibility, and a surge protector to withstand against the outdoor elements.
SIMPLE WIRELESS SOLUTION
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna is ideal for operating in modes such as multi point-to-point WDS, access point, and others that require a wide coverage range with its built-in high gain antennas. This is a cost effcient solution, especially when setting up a comprehensive hub in hot-spo
General features
FREQUENCY RANGE
	2.4GHz to 2.5GHz
	STANDARDS
	+ IEEE 802.11g
	+ IEEE 802.11b
	IMPEDENCE
	50 Ohm (nominal)
	VSWR
	1.92:1 (maximum)
	RADIATION
	Omni-directional
	POLARIZATION
	Linear vertical
	HPBW/HORIZONTAL
	360˚
	HPBW/VERTICAL
	6˚
	PEAK GAIN
	12dBI typical
	RADOME COLOR
	White
	EXTENSION CABLE
	N-Plug to RP-SMA Plug
	ANTENNA CONNECTOR
	N-Jack (female)
	EXTENSION CABLE LENGTH
	50 cm (0.5 m)
	DIMENSIONS
	1718 x 48 mm (67.64 x 1.89 inches)
	WEIGHT
	1.2 kg
	OPERATING TEMPERATURE
	-40˚ to 80˚C
	STORAGE TEMPERATURE
	-40˚ to 80˚C
	OPERATING HUMIDITY
	90% at 25°C
