ANT24-1202EOL EOS
OUTDOOR OMNI-DIRECTIONAL ANTENNA
Description
OPTIMAL PERFORMANCE
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna is designed to be used in conjunction with devices at the 2.4GHz frequency, and compliance with the b and g standards. It offers a powerful omni-directional signal at a high 12dBi gain that can effectively redistribute a wireless signal to multiple remote locations at a wide range from an access point or bridge.
CONVENIENCE OF FLEXIBILITY
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna features a very durable build that grants users with great fexibility. Its waterproof design provides users with the facility of choosing placement in or outdoors. The antenna also includes an N-Type to RP-SMA adapter cable for added compatibility, and a surge protector to withstand against the outdoor elements.
SIMPLE WIRELESS SOLUTION
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna is ideal for operating in modes such as multi point-to-point WDS, access point, and others that require a wide coverage range with its built-in high gain antennas. This is a cost effcient solution, especially when setting up a comprehensive hub in hot-spo
General features
FREQUENCY RANGE
2.4GHz to 2.5GHz
STANDARDS
+ IEEE 802.11g
+ IEEE 802.11b
IMPEDENCE
50 Ohm (nominal)
VSWR
1.92:1 (maximum)
RADIATION
Omni-directional
POLARIZATION
Linear vertical
HPBW/HORIZONTAL
360˚
HPBW/VERTICAL
PEAK GAIN
12dBI typical
RADOME COLOR
White
EXTENSION CABLE
N-Plug to RP-SMA Plug
ANTENNA CONNECTOR
N-Jack (female)
EXTENSION CABLE LENGTH
50 cm (0.5 m)
DIMENSIONS
1718 x 48 mm (67.64 x 1.89 inches)
WEIGHT
1.2 kg
OPERATING TEMPERATURE
-40˚ to 80˚C
STORAGE TEMPERATURE
-40˚ to 80˚C
OPERATING HUMIDITY
90% at 25°C
Certificates
Order info
ANT24-1202 OUTDOOR OMNI-DIRECTIONAL ANTENNA
Pictures
ANT24-1202/Ax
Front view
Downloads
Support Resources
