Description
The DSL-1500G G.SHDSL router customer premises equipment (CPE) provides small offices and telecommuters the features and speed they need for bandwidth-demanding applications. It also gives service providers a platform that allows them to offer high-margin, value-added business services while helping them reduce the cost of deployment and services.
Higher Speed & Longer Distance Coverage
The DSL-1500G router's embedded G.SHDSL is the latest version of DSL technology. It provides your business a symmetrical service for bandwidth-intensive applications. G.SHDSL can support speeds both upstream and downstream of up to 2.3 Mbps, compared to 2.0Mbps for SDSL. It can also be deployed nearly twice as far from the central office (CO) than SDSL, which is limited to a maximum distance of 5,400 meters (18,000 feet).
Multi-Vendor Equipment Deployment Capability
G.SHDSL multi-rate DSL combines the best of SDSL and HDSL2, it's aimed at users of DSL for voice, data and Internet access services. It's a global standard (G.991.2) developed by the International Telecommunications Union's (ITU) Telecommunications Standards Sector based in Geneva. By contrast, SDSL, the current DSL service of choice for business applications, is hardly recognized outside North America. With a widely adopted standard, G.SHDSL makes it possible for telecom and ISPs to achieve cost reduction and interoperability by deploying equipment across vendor boundaries.
Cost-saving Internet Functions
The DSL-1500G router is ideal for small offices or home offices and saves you the cost by allowing your office users to share a single G.SHDSL line and a single IP address/ISP account. This router's built-in DHCP server automatically assigns IP address for all office users, simplifying everybody's logon operation.
Firewall Security
With the always-on connection that G.SHDSL provides, network security is essential. The DSL-1500G router's basic NAT firewall protects your office computers from attacks from the Internet. NAT provides security by allowing users to hide behind a single public IP address, keeping your PCs behind the router concealed from public view.
General features
DSL Standard
ITU G.991.2 (G.SHDSL) standard, Annex A, Annex B
Data Rate
Up to 2.3Mbps symmetrical
G.SHDSL Interface
- RJ-11 connector for phone line connection
- Micro filter required for analog phone set/G3 fax machine
WAN Protocols
- Bridged/Routed Ethernet over ATM (RFC 2684)
- Classical IP over ATM (RFC 1577)
- PPP over ATM protocol (RFC 2364)
- PPP over Ethernet (RFC 2516)
Signaling
- ATM signaling: UNI 3.1, 4.0
- OAM F4/F5 Loopback
IP Packet Routing
- DHCP/NAT
- IP filtering
- TCP/IP with RIP-1 and RIP-2, Static Routing
- ICMP (RFC 791)
- UDP (RFC 792)
- ARP (RFC 826)
IP Routing Protocols
- RIP-1 (RFC 1058), RIP-2 (RFC 1389)
- Static Routing
Internet Support
- Dynamic Host Configuration Protocol (DHCP) server (RFC 2131), client (RFC 2131)
- Network Address Translation (NAT)
User Authentication
- PPP Authentication Protocol (PAP) (RFC 1334)
- Challenge Handshake Authentication Protocol (CHAP) (RFC 1994)
LAN Interface
- 10/100Mbps 10BASE-T/100BASE-TX port
- Network speeds auto-sensing, full/half duplex support
Others
- Simple firewall (NAT)
- Reset button (default factory configuration reset)
Configuration/Management
- Web-based
- Telnet
Console Port
DB-9 RS-232 DCE mode, up to 9600 baud rate
