DSL-6540UEOL EOS
VDSL2 MODEM ROUTER
Where to buy
Description
ULTIMATE INTERNET CONNECTION
The DSL-6540U VDSL2 Modem Router is a versatile, high-performance router for the home and small office. With integrated VDSL2 supporting up to 80 Mbps download speeds, firewall protection, Quality of Service (QoS), and four Ethernet switch ports, this router provides all the functions that a home or small office may need to establish a secure and high-speed remote link to the outside world.
FIREWALL PROTECTION & QoS
The DSL-6540U VDSL2 Modem Router provides firewall security using Stateful Packet Inspection (SPI) and hacker attack logging for Denial of Service (DoS) attack protection. SPI inspects the contents of all incoming packet headers before deciding which packets are allowed to pass through. Router access control is provided with packet filtering based on port and source/destination MAC/IP addresses. Quality of Service (QoS) supports multiple priority queues to enable a group of home or office users to experience the benefit of a smooth network connection without having to worry about traffic congestion. QoS support allows users to enjoy high-speed VDSL transmissions for applications such as VoIP and streaming multimedia over the Internet.
INTEGRATED HOME SERVICES
The VDSL2 standard provides speeds fast enough to support the integration of services in the home such as digital TV or video on demand. VDSL2 provides users with a suitable solution for both home entertainment and communication needs.
General features
DEVICE INTERFACES
• 1 RJ-11 VDSL port (to VDSL line)
• 4 RJ-45 10/100BASE-TX Ethernet LAN ports with auto MDI/MDIX (to computers)
• Factory reset button
• Power ON/OFF switch
VDSL2 FEATURES
• VDSL Transmission Band Plan: ITU-T G.993.2
• VDSL Duplex Method: Frequency Division Duplexing, FDD for both DS/US
• VDSL Line-code Scheme: Multi-Carrier Modulation (MCM)
• VDSL Handshake Procedure: ITU-T G.994.1 compliant
• VDSL Physical-layer supports Packet Transport Mode (PTM)
• Supports Rate Adaptation
• Supports VDSL Line Status
• Performance: 80 Mbps downstream, 40 Mbps upstream
NETWORK PROTOCOLS & FEATURES
• NAT/NAPT (RFC 1631)
• RIP v1 (RFC 1058)
• RIP v2 (RFC 1389)
• Static Routing
• DNS
• TCP/UDP
• ARP/RARP (RFC 826)
• ICMP (RFC 791)
• DHCP Server/Client (RFC 213)1
• IP Multicast - IGMP Proxy/Snooping
• UPnP Compliant
• Virtual Server
• 802.1Q VLAN
• DMZ
• SNTP
FIREWALL/ACCESS SECURITY
• Built-in NAT firewall
• MAC Filtering
• Packet Filtering
• URL Filtering
• Denial of Service (DoS) prevention
• Challenge-Handshake Authentication Protocol (CHAP)
• DMZ
CONFIGURATION/MANAGEMENT
• Quick Installation Wizard
• Web-based GUI for remote/local management
• Firmware upgrade, configuration data upload/download via Web-based GUI
• Telnet for remote/local management
• Syslog monitoring
• SNMP v.1, v.2c support with built-in
MIB-I & MIB-II (RFC 1213)
• TR-069
QoS
• Traffic Prioritizaton/Classification
• Port-based priority
• 802.1p (0~7) priority  Diffserv-Codepoint IPQoS (TOS, 0~63)
• Source/Destination IP/Port-based priority
• Application port-based priority
• User-defined priority (TCP/UDP/ICMP)
SECURITY/BANDWIDTH MANAGEMENT
• IGMP Snooping v2/v3
• VLAN port mapping
DIAGNOSTIC LEDs
• Power
• LAN
• VDSL
• Internet
POWER INPUT
Through 12 V/1 A external power adapter
DIMENSIONS (L x W x H)
182 x 119 x 137 mm
OPERATING TEMPERATURE
0 to 40 ˚C (32 to 104 ˚F)
STORAGE TEMPERATURE
-20 to 70 ˚C (-4 to 158 ˚F)
OPERATING HUMIDITY
5% to 95% non-condensing
CERTIFICATIONS
CE
Certificates
Order info
Pictures
DSL-6540U
Back view
Front view
Downloads
Support Resources
