Quick find
Product features:
G.SHDSL termination unit
Project
General features:
Model
• DSL-1510G, 2-wire, 4 Ethernet ports
Line interface - G.SHDSL.bis
• Type: 2-wire
• Speed: n x 64kbit/s, n=3~89, n=3~213 (for extended mode)
• Standards: ITU-T G.991.2, ETSI 101 524
• Connection protocols: IEEE 802.3ah EFM 2Base-TL; TDM; DBM; HDLC
• Connector: 1 x RJ-45
• Line Coding: TC-PAM 16/32/64/128
• Impedance: 135Ohm
• ITU K.21 compliant
Ethernet interface
• Ethernet type: 10/100 BaseT
• Connector: RJ-45
• 802.3x flow control support
• Auto MDI/MDIX on all ports
• Auto-negotiation of speed and duplex mode
• Supports full-duplex and full-duplex modes
Clock source function
• Internal
• Resulting from the DSL line
Ethernet level 2 functions
• Supports 802.1d transparent bridge
• Supports MAC-filtering
• Bandwidth control on each port (Step=64K, up to 100M)
• Up to 2K (2048) learned MAC-addresses
• Supports Ethernet packet size up to 1518/1522/1536 bytes
• Supports 802.1q VLAN tagging
• Supports 802.1p QoS
Management
• Setting up a CID console (debug only), Telnet, web UI
• Supports web browsers: IE, Firefox, Chrome
• Console connector: DB9 (RS232C)
• Supports remote management
• Local and remote loop diagnostics
• Performance monitoring
• TST button to verify the working capacity of DSL connection
• Reset button to restore the default settings
Indicators
• PWR, TST, ALM, CPE, DSL 1~4, LAN 1~4
Power
• AC/DC, DC/DC external power supply (12V, 1A)
• Dual power connector 12V DC for power backup
• Power consumption: 6W
Dimensions
• 200 x 150 x 39mm
Operating conditions
• Operating temperature: 0°~50°C
• Storage temperature: -40°~70°C
• Humidity: 90% non-condensing
Products | Support  | News  | About |
