DSL-500GEOL EOS
ADSL Router for Home/SOHO
Where to buy
Description
Simplified, Cost-saving Broadband Internet Connection
With this router, you can easily share your ADSL broadband line in your office or at home. To let everybody logon, this device automatically creates and assigns an IP number for each user, simplifying everyone's logon operation.
Network Security
The router provides NAT protection for your office and home users from any Internet intruders and hackers, plus VPN pass-through for extra security. It also blocks and re-directs certain ports to limit the services that outside users can access your network. Virtual Server Mapping is used to re-task services to multiple servers. The router can be set to allow separate FTP, Web, and Multiplayer game servers to share the same Internet-visible IP address while still protecting your servers and workstations from hackers.
DMZ Host to Open Public Domain
You can configure any of the built-in LAN switch ports to function as a DMZ port. A DMZ setting can be applied to a single client (such as a Web server) behind the router to fully expose it to the Internet and ensure complete Internet application compatibility even if the specific port is not known. This allows you to set up web sites and e-commerce business from your office while maintaining protection for the rest of your office LAN.
General features
Certificates
Order info
Pictures
DSL-500G
Front view
Downloads
Support Resources
