Quick find
Product features:
External power supply for DAS-4672, 1008 W
Project
General features:
Built-in protective mechanisms
• Overload protection is triggered when the output power exceeds the nominal value of 5%-35%
• Protection against the output voltage exceedance and short-circuit is triggered when the output voltage is from 56.6 V to 66.2 V
• Protection against high temperatures
Ventilation
• Built-in DC fan
Input voltage range
• 90 to 264 VAC
• 124 to 370 VDC
Range of the input AC voltage
• 47 Hz to 63 Hz
Leakage
• <2.0 mA at 240 VAC
Output voltage
• 48 V
Nominal output current
• 21 A
Range of output current
• From 0 to 21 A
Rated power output
• 1008 W
Dimensions
• 295 x 127 x 41 mm
Temperature
• Operating: -20 to 60 °C
• Storage: -40 to 85 °C
Humidity
• Operating: 20% to 90% non-condensing
• Storage: 10% to 95% non-condensing
MTBF
• 35,000 hours at rated voltage lines, maximum load, ambient temperature of 25 °C
Safety
• UL
• TUV
Products | Support  | News  | About |
