Quick find
Product features:
Management Module for DMC-1000
Project
General features:
Number of Ports
• 1 x 10/100/1000BASE-T RJ-45 port
• 1 x RJ-45 Console port
Diagnostic LEDs
• Power 1, 2
• Power Fail 1, 2
• Fan Fail 1, 2
• Console
• MGM
• Link/Activity
Chassis
• Part number
• Revision
• Description
• Chassis reset
• Power status
Media Converter Modules
• Link status
• Converter type
• Slot occupied
• Part number
• Revision
Alarms
• Cold start
• Warm start
• Link up
• Link down
• Authentication failure
• Power supply on/off
• Power supply insertion
• Power supply removed
• Module insertion
• Module removal
• Module unknown
• Module failure
Active Control
• Link Loss Carry Forward (LLCF)
• Link Loss Return (LLR)
• Module name
• IP address
• Reset module
• Redundant backup
• Download software via TFTP/HTTP
• Subnet mask
• Default gateway
• Telnet to console commands
Supported Protocols
• IP
• SNMP
• TFTP
• ICMP
• UDP
• TCP
• ARP
• HTTP
Weight
• 0.12 kg
Dimensions
• 120 x 88 x 25 mm
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Storage: 5% to 90% non-condensing
Certifications
• FCC Class A
• CE Class A
• VCCI Class A
Products | Support  | News  | About |
