DIR-100/FE/E1EOL EOS
Broadband Router
Description
High performance
D-Link DIR-100 Broadband Router is designed for sharing a broadband Internet connection through a DSL or cable modem by a group of users. Easy to install and operate, this router is ideal for novice users, which create their first networks at home and in small offices.
Quality of Service (QoS)
DIR-100 provides prioritized transmission and reception of VoIP and online traffic to/from the Internet, providing a group of users with reliable network connection with no traffic delays. QoS support provides broadband access for applications such as Internet telephony, multimedia and games on the Internet.
The high level of network security
Router DIR-100 is equipped with a firewall to protect the computers on the network from DOS attacks and virus attacks. With packet filtering the device provides port-based and source/destination MAC/IP-based access control. Using port forwarding feature the router can be configured to allow separate FTP, and game servers to share the same Internet visible IP address, and at the same time, servers and workstations will remain protected from hackers. Users can set up a home or office Web-site by configuring any of the built-in LAN ports to work as a port DMZ. The parental control feature allows parents and network administrators to filter out unwanted URL addresses of Web sites, block domains and control the time of the Internet operation via a schedule.
General features
WAN interface
• 1 Small Form-factor Pluggable (SFP) port for 10/100Mbps optical connector
• Supports DSL or cable modem connection
• Supports "Always-on" (bridged) and PPPoE for PPTP connection on demand
LAN Interfaces
• 4 port 10/100 BASE-TX Ethernet
• Supports auto polarity MDI/MDIX
• Supports 802.3x flow control (full duplex) and the back pressure method (half duplex)
VPN support
• PPTP pass-through
• IPSec pass-through
• L2TP pass-through
Internet gateway functions
• DHCP server (for automatic assignment of IP addresses)
User access control
• MAC address filtering
• IP addresses filtering
• Scheduling
Firewall
• NAT (Network Address Translation) with VPN pass-through
• SPI (Stateful Packet Inspection)
Quality of service
• Transmission/receiption of prioritized VoIP traffic and streaming media
• IGMP (Internet Group Management Protocol) multicast stream
Configuration and management
• Quick Installation Wizard
• Remote management via Telnet
• Web interface using Internet Explorer v.6, Netscape Navigator v.7 or other Java-enabled browsers
• Dynamic Domain Name System (DDNS)
• Universal Plug and Play (UPnP) compliant
• Supports Network Time Protocol (NTP)
Firmware update
• HTTP (via Web browser)
Diagnostic LEDs
• Power/Status
• SFP (Link/Activity)
• LAN 1, 2, 3, 4 (Link/Activity)
Certificates
Order info
DIR-100/FE Broadband Router
Pictures
DIR-100/FE/E1/FE
Front view
Back view
Downloads
Support Resources
