DIR-140LEOL EOS
Broadband Cloud VPN Router
Description
	The D-Link DIR-140L Broadband Cloud VPN Router is an easy to deploy VPN router that combines the functions of a router, a 10/100 switch,VPN, and firewall into a single device designed specifically for the Small Office/Home Office (SOHO) market, which demands superior performance and security in a compact desktop chassis. With small businesses becoming increasingly network-dependent, the need to invest in a reliable security solution is crucial. The DIR-140L offers high return on investment through robust security features, flexible configuration, and superb network protection for small offices and home networks.
	User Configurable Interface
	The DIR-140L features an intuitive user interface that can easily be configured and monitored via D-Link’s web-based management interface. These configuration options can be managed through Admin or Read/Write administrator rights. With these access management levels, any authorized user can easily configure or access the management interface of the DIR-140L.
	Use mydlink to Monitor Your Network
	The Broadband Cloud VPN Router is mydlink Cloud enabled, so you can effortlessly access and view your network no matter where you are. See who is connected to your router, change settings, or block someone from using your network connection, all from any Internet connected PC, or an iOS or Android mobile device. Home users can check on their children’s web browsing habits, and business users can manage employee Internet activity, all while staying informed and in control on the go.
	Advanced Hardware Features
	The DIR-140L can be connected to a cable or DSL line to share high-speed Internet access. It also doubles as a 4-port full-duplex 10/100 switch to connect up to four Ethernet-enabled devices, and you can simply add more switches to expand your wired network. In addition, you can create a Virtual Private Network (VPN) with the DIR-140L and allow up to 25 off-site or traveling users to securely access your central network through the Internet simultaneously.
	VPN Performance
	For optimal VPN configuration, the DIR-140L has an integrated VPN Client and Server to support almost any required VPN policy. This device has a hardware VPN engine to support and manage up to 25 VPN configurations. The
	DIR-140L can support IPSec, PPTP, L2TP, and GRE protocols in Server mode and can handle pass-through traffic as well. Advanced VPN configuration options include: DES, 3DES, and AES encryption, IKE/ISAKMP key management, Main/Aggressive Negotiation modes, and VPN authentication support using the internal 10-user database.
General features
	Standards
	• IEEE 802.3
	• IEEE 802.3u
	Ports
	• Four 10/100 LAN ports
	• 10/100 WAN port
	• USB 2.0 port
	• RS-232 COM port
	• Kensington lock slot
	LEDs
	• Power/Status
	• LAN 1/2/3/4
	Device Management
	• Internet Explorer 6 or later, or another Java-enabled browser
	Firewall Modes of Operation
	• Layer 3 Mode: NAT Mode
	• Port Forwarding
	• Port Address Translation (PAT)
	VPN Security
	• VPN Tunnels: 25 (IPSec, PPTP, L2TP, GRE)
	• IPSec LAN-to-LAN / Remote User
	• IPSec/PPTP/L2TP Pass-through
	• PPTP/L2TP Server/Client
	• IPSec NAT-Traversal
	• XAUTH (Extended Authentication) for IPSec Authentication
	• Encryption Transform: DES, 3DES, AES
	Firewall Security
	• Internal User Database (10 records)
	Network Service
	• Static IP Address
	• DHCP Client for WAN Interface
	• Internal DHCP Server
	• Static Routes
	• DNS Resolving of Remote Gateway
	• PPPoE for xDSL
	• Russian PPPoE/PPTP (Dual Access)
	• Quality of Service
	• Dynamic DNS
	mydlink Features
	• Remote Management
	• View current upload/download bandwidth
	• View currently connected clients
	• View web browsing history per client
	• Block/unblock client network access
	• Accessible through a web browser or iOS or Android mobile app
Certificates
Order info
DIR-140L/A1A Broadband Cloud VPN Router
