DIR-457UEOL EOS
MyPocket 3.75G HSUPA router
Where to buy
Description
Wireless networking
The D-link myPocket 3.75G HSUPA router allows users to access worldwide mobile broadband networks. once connected, users can enjoy data transmission and media streaming on-the-go. Simply insert your UmtS/HSUPA SIm card, and share your 3.75G Internet connection through a secure 802.11g wireless network.
Multifunctionality
The D-link myPocket 3.75G HSUPA router can be configured to work as a wi-Fi router or 3.75G modem with the flip of a switch. Share Internet connectivity with your colleagues or family while travelling or at work. connect the D-link myPocket 3.75G HSUPA router to a Pc to enjoy personal access to the Internet.
Advanced network security
Keep your wireless network safe with wPA/wPA2 wireless encryption. the DIR-457U utilizes a built-in firewall to prevent potential attacks across the Internet.
Simple to install and use
The 3.75G HSUPA router can be installed quickly and easily almost anywhere. this router is great for situations where an impromptu wireless network must be set up, or wherever conventional network access is unavailable.
General features
GSM BAND (GSM/GPRS/EDGE)
• 850 / 900 / 1800 / 1900 MHz
• Power Class 4 (+33 dBm, 850 / 900 MHz) ƒ
• Power Class 1 (+30 dBm, 1800 / 1900 MHz)
UMTS/HSUPA BAND *
• 850 / 1900 / 2100 MHz
• Power Class 3 (+24 dBm)
DATA THROUGHPUT **
• Downlink up to 7.2 Mbps in HSDPA mode ƒ
• Uplink up to 5.76 Mbps in HSUPA mode ƒ
• Max. 54 Mbps in 802.11g mode
Standards ƒ
• 802.11b ƒ
• 802.11g
Wireless Security
•ƒ 64/128-bit WEP
•ƒ WPA-PSK & WPA2-PSK
•ƒ WPS-PIN
•ƒ Built-in firewall
VPN
•ƒ L2TP/PPTP/IPSec VPN Pass-through
Advnced functions ƒ
• Storage file sharing ƒ
• UPnP
• Port Forwarding
ANTENNA
• 3 Internal antennas
CARD SLOTS
• Standard 6-pin SIM card interface
• MicroSD card interface
LED Status Indicators
• Power Status
• Signal Status
DIMENSIONS (L x W x H) ƒ
• 110 x 65 x 13.6 mm
WEIGHT ƒ
• 103 grams
Operating Temperature
• 0 to 40 ˚C (23 to 104 ˚F)
Operating Humidity
• 10% - 90% (Non-condensing)
CERTIFICATION
• CE
• FCC
• NCC
• RoHS Compliant
* Supported frequency band is dependent upon regional hardware version. Supported UMTS bands include 850/1900/2100 MHz, 900/1900/2100 MHz and 900/2100 MHz.
** Data rates are theoretical. Data transfer rate depends on network capacity and signal strength.
Certificates
Order info
DIR-457U MyPocket 3.75G HSUPA router
Pictures
DIR-457U
Front view
Back view
Downloads
Support Resources
